10-20-2024
22:54
06:16
CrisVillaFitbit
10-20-2024
22:54
06:16
CrisVillaFitbit
Sometimes Sense is measuring the distance of the exact same course correctly and other times not. It seems to be getting worse. Can anyone suggest how to fix this issue please?
Moderator edit: edited title to clarity.
Welcome back to the Fitbit Community, @kazzam99.
Thanks for letting me know about this situation in regards to the GPS not tracking the data correctly.
I recommend you to restart your Sense and check you're wearing it correctly, I'm positive this will help you.
Best AnswerThanks for your suggestions. Unfortunately neither have worked. Do you have any other suggestions I could try?
