01-13-2022
14:06
11:34
LizzyFitbit
01-13-2022
14:06
11:34
LizzyFitbit
I'm on Fitbit Premium. When I look at the info it says "No Readiness Score/Please wear your device."
The only time I'm not wearing it is when it's charging. So usually 24 hrs a day, unless I have to charge it for 30 minutes. What do I do about this. I absolutely want a Readiness Score!
01-14-2022 07:10
01-14-2022 07:10
Hi, @Rivercat773, welcome to the community, you may be interested in this article What’s my daily readiness score in the Fitbit app? You will note you need to wear your device for at least 4 days. You will find that when you wake in the morning & open the Fitbit app (When it will sync) there will not be a score. Wait a little while and sync your phone app, (you will get an encouraging banner at the top of the screen) swipe up and you should see your sleep score and readiness score provided that you've been wearing your "Sense" for at least 4 days.
I hope this helps.
Cheers
Gr4ndp4 | UK
01-14-2022 07:10
01-14-2022 07:10
I hope this helps.
Cheers
Gr4ndp4 | UK
01-15-2022 16:37
01-15-2022 16:37
Thank you so much for the clarifications -- I was ready to send it back as a dud. I think it's going to be a huge help with both fitness and
keeping track of life.
Smiles,
Cat
Best Answer04-05-2022 03:40
04-05-2022 03:40
My readiness score has not been working for WEEKS!!! Much communication with the Fitbit support team - no solution so far an now they have closed my case😡 !!
It had worked properly for months but oddly enough although I have no score in the morning if I click on the individual elements of the readiness score it shows each score individually but it doesn’t give the overall score ( just shows 0 score) - which is so frustrating !!!! Anyone else experiencing this? Coincidentally ( or not?) this started day after renewing in full my annual subscription😡😡😡
04-05-2022 03:48
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
04-05-2022 03:48
@Dogmum , same here. I'm on Android, and Daily Readiness went down the drain with the last app update on march 24.
04-05-2022 04:06
04-05-2022 04:06
04-05-2022 04:47 - edited 04-05-2022 04:49
Hi, @Dogmum , allowing you've followed the advice in my earlier post may I suggest you check that you have not inadvertently cancelled your consent for Fitbit Data to be used to calculate your readiness score. Touch the readiness tile on your Fitbit app "Today" screen>touch the "settings" gear in the top right corner>check "consent" (it should offer you the option to withdraw the consent if you have granted it)
I'm on android Fitbit app version 3.56.1(20263688) and my "Sense" is on 44.128.6.12 - I continue to get my readiness score.
I hope this helps.
Cheers
Gr4ndp4 | UK
Best Answer04-05-2022 06:24
04-05-2022 06:24
I have given up. Unless Fitbit / Google has something particularly good up their sleeves when they launch their next devices, this is my last Fitbit. The main reason I bought Sense, was to have it all in one device. I knew I had to compromise on for example HR, a belt is more precise than a watch, but acceptable.
Sense main selling points at launch, was ECG readings, support for Google Assistant, EDA scanning, and battery life. They completely “forgot” to tell us that they had not got approval from regulatory authorities in most (all?) European countries. We got ECG in Norway one year after launch. ECG is a medical feature, so to get approval, the device, the app, and the website had to be available in local languages. The moment Fitbit had their approval the Norwegian (NorEnglish Is more precise, AI translated…) Fitbit discontinued the Norwegian website.
Google assistant just did not happen. According to customer service, located in a low cost Eastern European country, google has not launched Assistant in Norway. BS – we have had it since 2018. For the last year we have not been able to call customer service. It is understandable, I am quite sure their staff “learned” Norwegian from Duolingo 😁. Their English was not particularly good either. Besides, when Fitbit says they have Norwegian support, I refuse to speak English or any other language.
EDA scan went out the window with an update last year. Floor count is just hilarious. According to Fitbit I have climbed height meters = 6.8 times Mount Everest in the last 12 months. Fitbit does not acknowledge Sense altimeter does not work.
I have an expensive device, showing time, date, step count, SPO2, HR. But one thing I say for them, battery time is great! 😂
Best Answer04-11-2022 05:18
04-11-2022 05:18
Yes, same for me. Following to see what FitBit has to say.
Best Answer05-05-2022 03:40
05-05-2022 03:40
05-05-2022 08:14
05-05-2022 08:14
Hi, @Dogmum, this is very frustrating for you I'm sure. You do not mention the make or model of the mobile phone you are using, some require particular care Fitbit Supported Devices explains the issues, check you have the minimum O/S on your phone. I also recommend you look at the Fitbit app on your phone and make sure the battery-saving function for the Fitbit app is disabled (Some phones treat it as non-essential and put it to sleep where we need it to be running constantly in the background) clear the cache while you are there.
Cheers
Gr4ndp4 | UK
Best Answer05-06-2022 13:11
05-06-2022 13:11
Best Answer07-11-2022 21:15
07-11-2022 21:15
Did the issue get fixed yet? I was told I am wearing the device too tight. Altered it (even though it wasn’t) with no success. Extremely frustrating! If you have a magic solution, I would be so appreciative. Thanks so much!
07-17-2023 04:44
07-17-2023 04:44
I really don’t recommend keeping this. Will go back to Whoop. My scores are intermittent like every 3 or 4 days I get a score then nothing. It’s useless if that’s how this works
