01-05-2021 10:33
01-05-2021 10:33
Hello,
I tried to search this issue thoroughly before posting and I apologize if I missed the solution. Here is what I am experiencing. My new Sense is syncing data to my phone. I see my steps etc. But the Bluetooth app won't allow me to change permissions for the watch - so I can see text messages and phone calls. When I select Sense from the list on the Bluetooth page, I get the message "An app is needed to use this device".
Phone is Samsung Galaxy S10.
Model SM-G973U
I have tried the following:
1. Uninstall/Reinstall Fit Bit App
2. Restart phone
3. Turn off/on watch
4. Remove and add Watch to App
5. Moved away from or turned off other bluetooth items.
I feel like there is a setting in the App that I am missing??????
Sure hope there is a fix.
Best Answer01-05-2021 12:17
01-05-2021 12:17
@PlankintheLou, you don't set the permissions in the phone's Bluetooth setting, but in the App settings. Open the phone's Settings->Apps->Fitbit->Permissions, and enable the permissions for the desired notifications. Bluetooth is simply the communications protocol, and the permissions are controlled by the phone's app settings.
Best Answer01-06-2021 07:12
01-06-2021 07:12
USAF - Larry,
You were right in that I didn't have all my permission selected. Thank you so much for the response. How did I miss that? So I have corrected this and I am still not seeing texts. I did restart both phone and watch and test again with no luck.
As for Bluetooth "settings" - what I am expecting to see is that when I select the Sense, it doesn't give me an error message and then it shows that SMS and calls are allowed. I previously used a Garmin and this is what I saw under Bluetooth with that.
I am open to more suggestions and help. I am enjoying the other features on the Sense but not seeing my texts is a deal breaker for me.
Best Answer01-06-2021 11:39
01-06-2021 11:39
Just in case you missed it
Swipe the watch to the right and make sure all the 6 icons are greyed out except the middle bottom one.
It could be you accidentally got it in sleep or do not disturb mode.
