06-07-2021 17:46 - edited 06-28-2021 11:19
Hi there,
Our team has released the new Fitbit iOS App 3.43 version and it should be available for all of you. Please make sure to download it from the App store as this will resolve the battery short life issues experienced on your Sense. Take in mind that this and future Fitbit app versions will require iOS 13.4+.
Hi everyone. Thanks for your continued reports.
Our team is aware of the Sense not holding charge when syncing with iOS devices and they're working to bring a fix as soon as possible. In the meantime, we recommend force quitting the Fitbit app on your iOS devices to prevent the battery from draining when syncing.
I've moved your posts to this thread so we can keep our team informed of this situation. Your patience is truly appreciated and please know your feedback hasn't gone unnoticed.
See you around.
05-28-2021 05:58
05-28-2021 05:58
I started having this issue. Changed to 100% at 8pm. This morning at 5:30am my battery is down to 47%. I did a factory reset the day prior as I was having synching issues. I was then prompted to update my firmware. What was loaded was 44.128.4.17. Immediately I noticed a high degree of battery drain after the update. Is there something about this firmware which maybe be causing it? I am using the SP02 watch face and have the Alexa integration active. However this is no different than I had it prior. Is it possible to reverse the firmware running on my sense? This is not acceptable in terms of battery life. I will have to charge it later this afternoon at this rate.
05-28-2021 13:13
05-28-2021 13:13
My Fit Bit Sense battery is dying very quickly. I am either looking for guidance or wondering when Fit Bit is going to recall this watch for not meeting the performance promised?
05-28-2021 16:38
05-28-2021 16:38
Hi @HLBD,
Just curious, how long is your battery lasting and do you have notifications turned on?
one cruise ship at a time!05-28-2021 22:07
05-28-2021 22:07
I have has my fitbit Sense for 6 months with no issue. It has fitbit premium but the standard clock face set to dim and no additional features. The battery is now lasting less than a day after a full charge.
05-28-2021 22:40
05-28-2021 22:40
There's a known iOS Fitbit App problem, so probably not a watch problem.
Have a look at these posts it may apply and can help in the mean time.
06-02-2021 11:52 - edited 06-02-2021 11:54
@Teecher Thank you! Your advice of trying a factory reset fixed it. Been going strong for 5 days now.
If anyone is still having this issue, this should be step number 1. If you’ve already tried it make sure to mention it because if it doesn’t work for you that indicate two different issues with battery draining.
If you haven’t tried it, here are the steps… “On your Sense go to Settings, About, Factory Reset.”
06-02-2021 21:34
06-02-2021 21:34
I have had my Sense for about a month. It was awesome for the first 3 weeks. I plugged it in on Monday night before I went to bed because it was just about dead after many days. I put it on yesterday morning at 8:45 am and by 10pm, it was DEAD. I plugged it in again overnight and put it back on this morning at 8:45 am and of right now at 12:29 am, I've lost over 50%. So very frustrating to spend so much money for one month of use. My Alta lasted better than this "better" version. I want my money back.....
06-03-2021 04:07
06-03-2021 04:07
This latest update has severely increased the battery load… previously my senses dropped about 11pc per day… it now drops 34pc per day! Not good!!
06-03-2021 05:08
06-03-2021 05:08
I only got my sense last week and I’m so disappointed with it, the battery last either a day or a night and then goes completely dead. I’ve had to charge it when I wake up and at night when I get in from work! It’s ridiculous - I don’t have an always on screen and I check the time/my steps maybe 3 times per day so this should NOT be happening. Think I probably have to bring it back
06-03-2021 06:08
06-03-2021 06:08
My Sense updated yesterday and now I can’t even get 12 hours out of a charge. Used to get a couple of days!
06-03-2021 06:17
06-03-2021 06:17
This is a known issue in the iOS Fitbit App and not a fault with the watch.
Have a look at these posts it may apply or help in the interim.
06-03-2021 08:44
06-03-2021 08:44
With the latest firmware update, the battery isn’t lasting even half a day - 10 hours on full charge. It used to last 5 days before the firmware update. All settings remain same in terms of display, spo2, gps etc
06-03-2021 10:29
06-03-2021 10:29
My Sense updated yesterday morning and I’ve had to charge it twice! Didn’t even last the night. Charged it 5 hours ago and it’s already down to 50%
06-03-2021 11:22
06-03-2021 11:22
Battery drained in less than 12 hours after yesterday’s firmware update! Please fix this ASAP
06-03-2021 13:43
06-03-2021 13:43
Mine too. That update. Charged 100% at 8am and going on 4pm, down to 20%. What’s going on?? It use to last 3 or 4 days
06-03-2021 14:24
06-03-2021 14:24
I had the same issue, was told it’s an issue with app. Turned phone off and left it turned it back on after a few minutes, all battery now working fine, But now I can’t get watch to sync with the app at all 🤦🏼:female_sign:
06-03-2021 14:43
06-03-2021 14:43
Updated my sense yesterday which fixed my syncing issue but it’s draining the battery in a day. Any idea why?
06-03-2021 15:22
06-03-2021 15:22
Is this going to fix the draining battery problem? Because I got the update last night and there has been no improvement to my Sense. It only holds charge for a few hours.
06-03-2021 15:48
06-03-2021 15:48
Same issue as well. Battery is draining far too quickly after the firmware update..
06-03-2021 16:34
06-03-2021 16:34
