07-22-2021
13:56
14:51
LizzyFitbit
07-22-2021
13:56
14:51
LizzyFitbit
Anyone else having serious issues with sense control Bluetooth connection - never allows me to connect and always says unsuccessful - tried several times to delete and go again but just not working. Any advise please??
Moderator Edit: Clarified subject and updated label
Best Answer07-23-2021 14:47
07-23-2021 14:47
Hi @churchie23489. It's good to see you around.
Thanks for every step tried prior to posting. Before anything else, let me explain that it's expected to see the Sense controls disconnected as they'll connect as soon as you receive a call on your Sense. On the other hand, if the on-wrist phone calls aren't working correctly or if the notifications aren't going through, I'd recommend the following steps
Once this is done, please set up the notifications and the on-wrist phone calls one more time, and monitor your watch's behavior.
Hope this helps.
