Sense counting steps while sleeping
I upgraded from Charge 2 to Sense and Sense counts steps while I'm sleeping!!
It is annoying to see 500 steps when waking up, my old Charge 2 did a much better job.
Is there a way to fix this?
I like the Sense a lot but if I can't trust what it measures I'll give it back and keep the old Charge 2
26 REPLIES 26
Upgraded from a charge2 a week ago and thia.morning when I woke up the sense had logged over 23k steps!  First time this happened since starting to use the sense.  Why is this happening and can I delete the steps that are obviously incorrect?
Hello,
I have the Sense also and have had it for nearly a year now. It also tracks a large amount of steps (Between 11k and 40k) while I am sleeping (like from 1am to 1:15am). It is set to normal and I wear it as snuggly as I can. I have also tried resetting it.
Counted 4,980 steps while sleeping.  Sleep sensitive on normal, restarted. Now what?
Hello @JuanFitbit
I have had the Sense for 5/6 days and all seems good so far, except last night between 3:44 am and 3:46 am while I was sleeping the step tracker recorded 5,450 steps in a single minute.
Hi everybody! Thank you foro your reports.
If you already followed the steps described here and also have restarted the Sense, and the situation appears again, please give us a call or chat with us. Click here to get connected
See you around.
I'm having this problem also.  I checked and Sleep Sensitivity is already set to Normal.
Alicia H.
@amheyman Nice to see you around. Thank you for your report.
I'll be glad to inform you all here, should I receive further information regarding this issue.
Thank you for your comprehension and patience.
