08-02-2023
12:10
07:24
08-02-2023
12:10
07:24
My Sense has completely stopped working. I am so sad as it was a gift and I am lost without it. Tried a new charger but the screen is completely black.
Hi @LeanneJH - it sounds as if it needs charging, changing power source, preferably a PC port is a good idea but also check these instructions How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
There can be other reasons the screen is blank, so try double tap and swipe in any direction, if this works change the clock face.
Also check the Quick Settings (swipe face to the right)
Another test is to sync the watch. If it works the display be faulty, otherwise it may need charging still.
Lastly hold the button for 10 seconds till it vibrates and the logo appears and wait for it to start if it is merely having some difficulty.
Hi there, @LeanneJH. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Sense before reaching out.
As @Guy_ has suggested, please try the following steps:
If the above doesn't work, I recommend performing a factory reset on your Sense:
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
Best AnswerThank you very much, I have tried to do everything you have mentioned but my screen still remains black. It won't synch or charge either.
Best AnswerHi Leanne, have you checked your charging cable? The common defect is one of the prongs or broken. It just happened to me.
Best AnswerI have the very same issue. They sent me another watch and it does the same 😮
