09-28-2024
19:18
14:31
FatimaFitbit
09-28-2024
19:18
14:31
FatimaFitbit
My Fitbit Sense watch will not charge. I have cleaned the back of the watch and also cleaned the charging pad
09-30-2024 00:25
09-30-2024 00:25
I am having the same problem, the magnet connects with back of watch and it starts making a buzzing noise but it’s not charging - it’s about two years old and i don’t know what to do about getting it seen to
09-30-2024 05:38
09-30-2024 05:38
I also have the same problem, I asked for a call back and before I could respond it said that as I didn’t respond the call was cancelled. Now the app says the problem is ongoing and won’t let me ask again. I have cleaned both watch and charger and tried using different ports to charge it. Thinking of buying a new cable. What have anyone else done to cure this issue?
Best Answer09-30-2024 11:29
09-30-2024 11:29
One possible solution: These chargers have a common problem with one of the 4 pins receding slightly so that it no longer makes contact. I have not seen anyone here able to fix it. I can't guarantee that is the issue for any of you but take a close look at the pins and if so, my suggestion is to order off-brand name replacements from Amazon, much quicker and cheaper than trying to get originals from Google, if even still selling them. Get a set of 2.
Best Answer09-30-2024 14:17
09-30-2024 14:17
Best Answer09-30-2024 15:58
09-30-2024 15:58
I have checked the Amazon cable and one of the reviewers have stated that one of the set of two that he bought melted after a few months and was therefore a fire risk and urged people not to buy them.
Best Answer10-03-2024 14:29 - edited 10-03-2024 14:31
Hi everyone! So nice to see you here in the Community!
Thank you so much for letting us know that you're having trouble charging your Sense 2 and for your efforts. @JohnnyRow Thanks for the input too!
I suggest you check first if you can update your devices. Please try to follow these steps too: Why isn't my Fitbit device's battery charging?
@mofitz I've been informed that you have contacted our customer support, please continue working with them, they will take care of you. @SwimmerJa,@tripletxxx please, if you need more assistance after you tried all the steps, contact us.
