11-04-2020 06:21
11-04-2020 06:21
Hello, I was curious if anyone has found a way to make the sleep score on the watch face? It used to show and now it is not showing anymore, but it does show in the app.
03-08-2021 01:14
03-08-2021 01:14
Sync of sleep score to Sense's Spectrum watchface works for me most of the days. Seldom, the sleep score does not sync to the watch and I've found there is no clear way how to solve it reliably. Out of all the tips mentioned in this thread, some work one day and then the next day have no impact.
03-14-2021 21:02
03-14-2021 21:02
This has happened to me twice. It happened about a month ago and then again just yesterday. For no reason at all it just stopped showing up on the watch face. I fixed it the last time by completely resetting the watch as if from new and also logging out and uninstalling the Fitbit app on my phone. That was a really time-consuming process just to get the sleep score to show up. I really hope there would be something better. It seems like the Fitbit software people just don't care about this issue. It's enough to make me dump Android and just get an Apple watch because they never have issues like this. I'm not an Apple fan at all but at least their stuff just seems to work most of the time. My wife has never had issues with her Apple watch.
03-17-2021 17:32
03-17-2021 17:32
I stumbled my way to this fix. Not sure if it will work for all: From main watch face, swipe up > scroll to bottom, hit Manage > More Widgets > hit + sign next to sleep tracking. When I returned to main watch face, sleep tracking was back. Note that the device was sleep tracking previously, but it was only visible on the app. Hope this helps.
03-25-2021 12:24
03-25-2021 12:24
More reliable fix: Go into app and sync. Press sleep function and it pops up on watch. Clunky and frustrating, but works fairly consistently.
06-11-2021 08:12
06-11-2021 08:12
I've noticed an improvement since the last FW update to v44.128.5.38
I haven't had an issue with sleep score syncing to the Sense Spectrum watch face since the FW update. Moreover, I've noticed that on days when I updated my go-to-bed-time, which then led to sleep score being recalculated in the app, the sleep score even correctly re-synced to the Sense watch. It never did update like this in the past. So let's hope the sleep score syncing issues have been resolved once and for all now!
06-14-2021 08:46
06-14-2021 08:46
It turned out I was over-optimistic. Yesterday, the sleep score didn't sync again, so the problem persists even with the new firmware 😕
06-14-2021 19:01
06-14-2021 19:01
Just upgraded to fb Sense a couple of days ago. Experienced the same problem as above.
I may have found a solution. It seems that if I keep the fb app running in the background at all times on my iPhone, the Sleep score keeps on displaying on the watch.
06-16-2021 16:25
06-16-2021 16:25
The above stated work around did not work for a longer period of time. After a day the watch stopped displaying the Sleep score. Tracked down the possible reason to the "Not Connected" status of "Sense Controls" on my iPhone Bluetooth device connection status page. It seems that the iPhone no longer can see this BT device to connect to. Why fb uses the reg connection for communicating the Steps and the Heart rate but uses the Sense Controls to communicate the Sleep score is beyond me. Hopefully someone from fb would look into getting this fixed. A real turn down on me upgrading to Sense.
06-25-2021 23:25
06-25-2021 23:25
Thank you!! This worked. Mines never worked since I got it for my birthday in dec
10-05-2021 22:41
10-05-2021 22:41
i am also having endless problems with my new Fitbit versa sense. This is the fourth Fitbit i have bought, the most expensive one and seems to be the least reliable.
The sense control keeps disconnecting, i have to resync at least 8 times a day
The sleep display on the watch is always not showing
The steps on the app on my phone needs to be synched more that 20 times before it eventually syncs.
i am very frustrated as i have only had this watch for a little over a month.
Any advice would be appreciated.
I have switched the Fitbit and my phone off many times with no improvement.
Look forward to hearing from you
Regards
Gabi
10-05-2021 23:40
10-05-2021 23:40
10-06-2021 00:08
10-06-2021 00:08
10-06-2021 00:38
10-06-2021 00:38
Hi @GabiMurphy, what might help is logging out from the Fitbit app and logging back in again. See if it makes any difference. If not, maybe uninstalling the Fitbit app and reinstalling and reconnecting the device might help.
11-17-2021 13:27
11-17-2021 13:27
I also get the sleep score on the app on my phone, but on the watch face its just 2 lines with no numbers. Can someone help on this????
05-22-2022 18:42
05-22-2022 18:42
Has this issue been resolved? I've been having this issue for months and can't figure out a proper workaround, aside from manually restarting everything.
06-09-2022 19:07
06-09-2022 19:07
Affects me to
06-09-2022 19:18
06-09-2022 19:18
I have this problem and my watch will not reboot. I’ll be holding the left button in for ages & nothing happens it just stays black.
06-27-2022 01:31
06-27-2022 01:31
I just noticed that the issue resolved itself in the past few days. I have not needed to restart my watch or sync manually. The score just shows up. I hope it continues - it's good to see its been working now. Has anyone else seen this recently resolved on theirs?
06-27-2022 03:31
06-27-2022 03:31
06-27-2022 07:38
06-27-2022 07:38
Hi, @SunsetRunner, To reset you need to hold the side button for about 20 seconds and then release it when the logo appears, normal service should resume in about 35 seconds. I hope this helps.
Cheers
Gr4ndp4 | UK
