10-06-2020 10:57 - last edited on 06-02-2021 07:54 by AndreaFitbit
My new Sense has decided after working well since 25th September to no longer sync. I have only just noticed that it hasn’t been doing so since Saturday. No matter if I go to Bluetooth and switch it off or on and if I have tidied out all my previous Fitbit devices it still gets about halfway along then just sits there. Very frustrating!! Anyone else got a solution? I’m using an Apple phone with the latest iOS.
Moderator edit: format.
10-07-2020 10:24
10-07-2020 10:24
@Furlafan It's great to have you here!
Sorry to hear that your Fitbit Sense isn't syncing and thank you for troubleshooting this issue. I suggest you clear the link between your phone and your device by doing the following:
Let me know how it goes.
10-07-2020 10:24
10-07-2020 10:24
10-07-2020 11:09
10-07-2020 11:09
Thanks Alvaro, That sounds pretty much what I did yesterday. It didn’t work last night . However, I tried again this morning and it did sync. My steps since Saturday have updated on the app but all other data has been lost which for a short period of time I’m not concerned about.
Thanks for your help. Hopefully it won’t happen again.
10-07-2020 11:28
10-07-2020 11:28
@Furlafan thank you for the update.
Really happy to hear that your tracker is now syncing and sorry that some data was missed from it. If a device stops syncing avoid removing it as this may cause data loss and try the instructions in the link on the last bullet point.
01-27-2021 07:58 - last edited on 06-01-2021 10:07 by DavideFitbit
I’ve just had the exact same problem with my Sense. Bought about a month ago. Worked great and then stopped syncing and recording my sleep on 1/25/21 (today is 1/27/21). I did the same thing you did and it worked for one syncing but then stopped and info actually disappeared on the app. Just did what you were told to do on this site (before I hadn’t turned off both the Sense and the phone) and it seems to be working. Have you had anymore problems like this since October?
I have had this exact same problem. It is very frustrating. Why is this happening and will it continue?
01-27-2021 22:23
01-28-2021 03:08
01-28-2021 03:08
My sense stopped recording my sleep and oxygen too on the app. Exactly 3 days ago also. I got it for Christmas from my kids. I had to restart it 10 times now. Frustrating
01-28-2021 08:19 - last edited on 06-01-2021 10:08 by DavideFitbit
I saw that but I have an iPhone X.
01-30-2021 02:47
01-30-2021 02:47
The bug has been fixed. Its necessary to update the Fitbit App to 3.37.1, if you haven't already done so, and restart phone and watch to be sure. You can check version here
In the phone Fitbit App Click on profile photo [top left] Help & Support App Version at the top |
01-30-2021 03:09 - last edited on 06-01-2021 10:08 by DavideFitbit
This is happening to me to tried turning off Bluetooth forget device updated phone nothing works seriously starting to think it’s a problem with the sense!!!
Ok do I have to do this daily from now on because I seriously haven’t got the time.
01-30-2021 04:28
01-30-2021 04:28
What phone do you have?
Did you also restart both phone and watch?
What is currently displaying on the watch?
Can you please also confirm the versions of watch Firmware and Fitbit App
On the watch Swipe left Settings About Sense System Info Version [2nd field] Version at the top |
01-30-2021 04:54 - last edited on 10-16-2021 07:20 by JuanJoFitbit
I did this. So far it's syncing. Let's hope it works. I know it has it's
bugs because it's new. I just don't want my kids to have wasted their money
for Christmas present. They all have them and had no problems.
Apparently i needed to update the app so it's syncing so far. I am not tech
savvy. I'm old school and learning everyday. Now if someone could add to
this device a find keys button like find phone lol.
Moderator edit: merged reply
01-30-2021 05:09
01-30-2021 05:09
Might the problems with Sense and syncing be linked to battery level?
I could be wrong here but it seems like my Android 7.1 ap will sync with the Sense when the Sense battery levels are high and stop syncing below an as yet to be determined battery level.
OR
It is something to do with the Sense being connected via the USB charger lead to the windows 10 PC which is itself paired with the Android phone?
In any case, the only time my phone has synced with the Sense is when the Sense is plugged into the USB and the phone, PC and Sense are all together in the same place. I have tried all of the recommended actions - ALL of them several times. I have installed and uninstalled the App and I have also factory re-set the Sense.
As I write this, the Sense is charging, and it has synced for with the phone for the first time in about 24 hours. I am not confident however that they will continue to connect once I remove the Sense from the PC.
The Sense version is 44.128.4.17
and the app is 3.37.1
01-30-2021 07:39
01-30-2021 07:39
01-30-2021 09:43
01-31-2021 07:51
01-31-2021 07:51
I have owned my Sense fitbit since Christmas Day. It has synced correctly until 2 days ago. I read a few of the replies and was concerned about losing data by resetting the fitbit watch or reinstalling the Fitbit App. Hence, I decided to simply power down my android phone instead. Upon restarting my phone, I was able to open the fitbit app and initiating the sync feature and it worked. Now it's syncing again.
01-31-2021 10:40
01-31-2021 10:40
Yes, it seems to be working now - as I was posting into the forum the Sense was updating!
02-06-2021 12:25
02-06-2021 12:25
I had a Charge 3 followed by an Ionic and never had a problem syncing however my Sense has regular problems requiring me to restart it and my phone. Now I had to delete my Watch from the Fitbit app but it cannot find it! I need a watch that is reliable, what is my next step?
02-06-2021 21:18
02-06-2021 21:18
In the phone Fitbit App Click on profile photo [top left] Click +Set up a Device |
02-07-2021 01:20
02-07-2021 01:20
I have tried that many times, rebooted, turned Bluetooth off and on, just now it is finding my Sense but timing out
