03-07-2021 16:47 - last edited on 03-08-2021 14:50 by LiliyaFitbit
Over the past 2 days my Sense is barely tracking any steps at all on both the watch and app, all other funtions seem to be working properly. In a regular day I usually have between 13,000-17,000 steps but this has dropped to around 1000 each of the last two days with no change to my typical activity. I have tryed restarting the device with no change
Moderator edit: label
Best AnswerWelcome to the Fitbit Community, @Rp9 @Tsimmons54935.
Thanks for the details shared in your posts and for already trying to resolve the issue. I understand how you are feeling and would like to advise that factors such as device placement, dominant or non-dominant hand, and stride length affect the number of steps recorded. If you feel that your step count is inaccurate, confirm the following are correct in the Fitbit app:
For more information about the accuracy of Fitit devices, see How accurate are Fitbit devices? You can find our tips about improving accuracy at What are some tips to make sure my Fitbit daily activity is accurate?
Hope this helps!
Best Answer03-08-2021 16:05 - last edited on 03-08-2021 18:32 by LiliyaFitbit
It did NOT help. Thanks for trying --
Best AnswerThanks,
I appreciate the effort but this was not the issue. I have had this particular unit for about 5 months and multiple fitbits over the past many years and have not changed how I am wearing it etc. With that said it seems to be working normally again today, not sure why or how but hopefully it was a minor 2 day blip.
Should it occur again I will follow up
Thank you for your replies, @Tsimmons54935 @Rp9.
@Rp9 I appreciate the additional details and am glad to hear your watch is working normally today. I hope you continue enjoying the Fitbit experience without any issues and working on your goals.
@Tsimmons54935 I am sorry to hear the issue persists, thank you for your efforts. If you haven't done so, I recommend restarting your watch. Please also note that since we use height to estimate your walking and running stride lengths, you may want to measure and manually adjust these values if your legs are longer or shorter than average. For more information, see Can I change my stride length in my Fitbit account?
Hope this helps.
Best AnswerI tried restarting, changing the stride, changing height but my Fitbit Sense is still not tracking all my steps. Any other suggestions?
Best AnswerWelcome to the Fitbit Community, @4Melanie. Thank you for your reply, @Tsimmons54935.
@Tsimmons54935 I understand how you are feeling and recommend getting in touch with our Support team so they can look deeper into the issue and help you with this matter. Click here to get connected with them via chat or phone.
@4Melanie I am sorry that you are going through the same situation. I appreciate your troubleshooting efforts and would like to confirm if you noticed that your watch is not tracking all your steps during some kind of activity? I will be glad to investigate further.
Looking forward to hearing back from you.
