08-14-2021
10:19
16:42
SilviaFitbit
08-14-2021
10:19
16:42
SilviaFitbit
My FB Sense is recording that I am asleep after I’ve awakened for the day. Went on a bike ride and it recorded me as “awake” but sleep.
Best Answer08-14-2021 16:38 - edited 08-14-2021 16:38
Did you sync the watch when you woke up?
https://help.fitbit.com/manuals/manual_sense_en_US.pdf#page46
16:44
16:15
08-14-2021
16:44
16:15
@Clove6060 Thanks for your input.
@Ruthlezz01 Welcome to the Fitbit Community. Thanks for the detailed information shared.
It's odd what you're experiencing. Let's try restarting your Sense and make sure you're following these tips to properly wear it.
Hope this helps.
Best Answer08-15-2021 13:28
08-15-2021 13:28
I have a similar issue. I get up at 6:30 every morning and immediately get in the shower Sense always says I wake at 6:38.
14:57
16:15
08-17-2021
14:57
16:15
@Boo_F Hi there. Thanks for the details mentioned.
Let's try changing the sleep sensitivity to sensitive, this mode will record nearly all movements as time spent restless or awake, check out this article to check the instructions.
Hope this helps.
08-18-2021 01:39
08-18-2021 01:39
Thank you for your reply. I have changed the sleep setting to "sensitive" and will monitor how it does.
08-19-2021 04:03
08-19-2021 04:03
I've had the same problem for the past 4 days. I've had my Sense for about three months with no problems. Then 4 days ago, it started counting me as asleep until I synced the Sense, which was sometimes an hour after I actually woke up. I've reset the Sense and changed the setting to sensitive, and this morning it did the same thing. This seems like a firmware problem that Fitbit needs to fix, since lots of people seem to have the same issue.
08-20-2021 14:25
08-20-2021 14:25
The sleep tracking seemed to work ok this morning. I'll see if it does again tomorrow.
Best Answer08-21-2021 04:42
08-21-2021 04:42
Nope, I was wrong. I waited 10 minutes this morning to sync after I woke up. It recorded me asleep until I synced. It is not working properly and Fitbit needs to address this problem.
08-21-2021 06:04
08-21-2021 06:04
I’ve restarted and I’m wearing it properly. Can’t really think of a way to improperly wear a watch but I assure you it’s properly being worn. I’ve switched the sensitivity and it’s still not working. Last night I took it off for a few hours and it recorded me asleep. This is my 3rd Fitbit I’ve purchased and it’s the only one I’ve had issues with.
Best Answer08-21-2021 13:14
08-21-2021 13:14
Mine (Sense) keeps recording me as sleeping me as sleeping when watching TV or reading.
Best Answer08-21-2021 15:44
08-21-2021 15:44
It affected me too
11:45
16:14
08-24-2021
11:45
16:14
Hi there, for the ones that are new to the Fitbit Community, welcome.
Thanks for the troubleshooting performed and for sharing your experience tracking sleep. I see where your disappointment is coming from.
If you have tried the recommended steps mentioned previously and still experiencing difficulties, get in touch with our Support team through chat or calls.
Hope this helps.
Best Answer05-05-2022 05:53
05-05-2022 05:53
Changing th sleep setting to "sensitive" has not made any difference. My Sense still thinks I wake up at 6:38am when in fact by then, I'm already in the shower.
Best Answer05-05-2022 09:07
05-05-2022 09:07
Do the sync first thing when waking up.
