11-21-2021
05:09
13:28
LizzyFitbit
11-21-2021
05:09
13:28
LizzyFitbit
The side button won't work anymore. Why won't it work because I done nothing to it and how do I fix this problem?
11-21-2021
05:37
13:00
11-21-2021
05:37
13:00
Hi, @Nikki831 - check there is no dirt around the button, and restart your watch by going to the Settings menu on the watch and at the bottom, Shutdown. Wait 10 seconds and place on the charger to restart and charge it.
If you aren't used to using the button much, there is a knack which helps
Worn on the left arm -
rest your other thumb on the arm to the left of the watch and forefinger on the back of the hand and do a gentle squeeze of the watch |
11-22-2021
13:39
04:48
11-22-2021
13:39
04:48
Hi @Nikki831. Welcome to the Community. @Guy_ It's good to see you here.
@Nikki831 Thanks for bringing this to our attention. I understand how you're feeling and while reviewing your details, I noticed you already have a case created with our Support team. Please keep an open communication with our team, I'm sure they'll work on this situation and bring you back on track.
@Guy_ Thanks for your great suggestions. I'm sure your post will help other members experiencing similar issues.
