My Fitbit Sense won't charge. I followed a video and tried all of the tips, but still won't charge. I ordered a new charger in case that's the problem.
Best AnswerHi @k2wess see if this article helps, if not, get with support.
Hi @k2wess - if you tried all the possibilities in all likelihood it is a fault with the charge cable.
Carefully inspect the 4 pins, that they are all equally prominent and securely located, you can do this by pressing with the back of a finger nail, they should have the same pressure. You will probably find a fault with the bottom left pin [wire on the right].
If your watch is still under warranty you should be able to still get a free replacement.
You can contact Fitbit Support directly.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support from Fitbit
