01-17-2022 12:07
01-17-2022 12:07
My sense has been struggling to charge. I have followed all the guidance and I have replaced the charger and no luck. I have not had it long and it should not have these issues.
Best Answer01-17-2022 12:44
01-17-2022 12:44
Mine too! I was able to charge it initially, but it started telling me to use a different outlet, which I did, still no luck. I used a different USB port and it worked for a couple days then stopped. I used another port, same thing! At first I thought it burned the ports out but I can still use them to charge my iPhones but not my Fitbit.
01-18-2022 02:44
01-18-2022 02:44
I'm having same issue must be maybe Fitbit software it's self I'm wondering has anyone contacted Fitbit themselves.
01-18-2022 10:42
01-18-2022 10:42
This is a common problem, please check the terminals and the charge cable as described How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
01-18-2022 10:53
01-18-2022 10:53
01-18-2022 12:25
01-18-2022 12:25
Yeah spoke to chat line after trying cleaning it and different power points still no different but weird how all happen round same day and is it all sense watches brought last Xmas when arrived out. As mines just over 12 months old as was Xmas present 2020.
01-20-2022 02:16
01-20-2022 02:16
Ha Linda yeah had good results from Fitbit quick on helping. How u go with new cable did it fix the problem with recharging as interested in knowing. Someone on forum mentioned one of pins on charger which never paid attention when first got that one pin not fully out think they said left bottom or right bottom but said it's not as high as other three but mine was very much same as all I couldn't see difference.
01-20-2022 10:55
01-20-2022 10:55
01-20-2022 11:24
01-20-2022 11:24
Best Answer01-20-2022 15:14
01-20-2022 15:14
I’m also having this issue, as well as the “charging slowly, try a different outlet” message. It doesn’t matter where I plug it in though - it doesn’t seem to help. I will try cleaning the charger and the back of the phone. If that doesn’t work, I will call customer service for a new charger. I just bought this phone in September 2021, so this is not cool.
01-21-2022 12:42
01-21-2022 12:42
01-21-2022 13:20
01-21-2022 13:20
Thank you for your reply. I found the problem! One of the tiny posts on the charger cord that attaches to the back of the Fitbit was too short! Customer service sent me a new cord and it’s charging beautifully.
01-21-2022 14:45
01-21-2022 14:45
Best Answer01-21-2022 15:12
01-21-2022 15:12
I’m so glad that you found the solution to your issue!
I cleaned the back of my watch with an old toothbrush and rubbing alcohol, and the nubs on the charger with a Q-Tip and rubbing alcohol per the FitBit troubleshooting tips, and replugged it in, and it did charge to 100%. So that’s good.
I will say though that I also checked the nubs on the charger, and there is one that is way shorter than the other, so if this problem happens again, I will likely be requesting a replacement charger.
I also waited a really long time to download the FitBit update because the last time I updated my older model (I think it was a versa lite?), the screen died the next day. (Luckily, it was still under warranty, so they sent me a new watch right away. The customer service and turn-around time were very good.) With this watch (the sense), the battery charging issue - with it not charging when it was plugged in - began the day after I updated the watch. I had been getting the “charging slowly, try another outlet” message for a long time, but it always charged to 100%, even if it took a while. I think there are bugs introduced every time there is an update. Not just with FitBit, but with iPhones and anything technological.
01-21-2022 16:16
01-21-2022 16:16
