10-06-2023
12:13
06:26
10-06-2023
12:13
06:26
Hello. I’ve had this Sense since the exchange of the Iconic. I’ve always had trouble charging it. I’ve whipped both the back of the watch and the charging plate with alcohol wipes. I’ve replaced the charging plate (charger) 5 times since I’ve had this watch. Now it won’t charge at all. I’ve rebooted it several times. I have 0 battery life. Iv’e replaced the cord again and still nothing.
please I need help. I miss my Fitbit
I've been facing this issue since June. And I emailed Fitbit literally 20 minutes back and they say there's no email support and that I'll have to look at responses from the community or their help page. It's not charging since June despite replacing charging cable.
Hi all, be absolutely sure that there isn't a power source or charge cable issue and the watch has been properly cleaned as explained here
How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
If the watch gets hot when charging it is faulty, so stop immediately.
While on charge try holding the button for 10 seconds till it vibrates and hopefully the logo appears.
If after a few minutes of being on charge you get a blank screen when pressing the button for a few seconds [after removing it from charging] and then when left a day it produces a 0% again then the watch has partially charged but is faulty following a failed factory reset or more likely getting moisture in it. The latter you may possibly be able to see as condensation in the sensor windows on the back using a magnifying glass.
