09-02-2022
04:13
19:20
YojanaFitbit
09-02-2022
04:13
19:20
YojanaFitbit
When I want and where easier thank you as my device isn't syncing properly...
Also make spo2 and body temperature live as advertised
Moderator Edit: Formatting and word choice.
09-03-2022 05:27
09-03-2022 05:27
Sp02 is live when you go to sleep. It should be with your sleep information.
As far as syncing, while it may be a code issue, there's other contributing factors as well that can cause sync issues. One that comes to mind is server issues and bandwidth. If several people are trying to sync at the same time, servers can crash. That's not something a coder can control, nor can a user. That's an issue with the amount of servers Fitbit has available.
one cruise ship at a time!09-03-2022 05:27
09-03-2022 05:27
09-06-2022
06:12
19:19
YojanaFitbit
09-06-2022
06:12
19:19
YojanaFitbit
Yes well it's not about that
Moderator Edit: Word choice
09-08-2022 00:42
09-08-2022 00:42
Bluetooth and turn Bluetooth off and back on. Turn your phone or tablet off and back on. Uninstall and reinstall the Fitbit app. If your Fitbit scale won't sync after you reinstall the app, log in to your Fitbit account on a different phone or tablet and try to sync.
Regards,
