Some long term testing reveals the battery drain on a Sense which is shutdown is around 0.5% per day.
The restart process can use anything up to 0.5%, so after 42 days it has a minimal overall effect.
The time [date] was retained but the time tends to wander fractionally while shutdown and restarted, but on this model time isn't stopped.
@eznohstar - just in case you are interested, this a follow up to your original message which is now closed.
I have a Sense and Charge 5.
I will fully charge my Sense and turn it off. In a week of it being off, while wearing my Charge 5, the battery will be at 0% when I turn it back on.
Never understood my the battery loses so much power when being off.
Hi @Ghostman - unfortunately it probably indicates an inherent watch fault, especially if the watch uses a lot of battery when on.
See the original post with a similar issue.
If you want to follow battery evolution when on, the SimpleClockPro clock face records the battery level in it's logs each morning and records the charges and shows the expected autonomy which might be helpful. Watches of a certain age may discharge at a higher rate to start with but by the 50% level it should show a 5 day autonomy.
Sense battery works fine when I am using it. Its only when I power it off that it drains and doesn't hold its charge.
Did notice it loses about 1 percent of battery on a restart.
If you're comparing battery drain during shutdown for devices like the Fitbit Sense to other types of devices, you might want to track the efficiency of different processes, similar to how users optimize builds on tools like pathofbuilding.net for Path of Exile. Just like ensuring an optimal build that minimizes resource consumption, managing the power settings on your devices can also help minimize unnecessary battery drain, ensuring they stay efficient for longer periods.
Best AnswerHi, @pathofbuilding, you should review this notice, just posted Sense and Versa 3 Battery Performance Program - Fitbit Help Center
Cheers
Gr4ndp4 | UK
