10-12-2020
17:38
13:27
LizzyFitbit
10-12-2020
17:38
13:27
LizzyFitbit
Hi there,
I have selected messages as my default message service - but I only seem to get a notification that I have received a message and when I go to read it on my Sense Fitbit, it says 'I'm all caught up' - it doesn't actually show me the message. I can read all the incoming messages from WhatsApp and Messenger from my Sense however, just not messages (SMS). Why is this?
Moderator Edit: Clarified subject and updated label
13:51
05:22
10-13-2020
13:51
05:22
Hi @flowerpower_74. Welcome to the Community Forums.
Thanks for letting me know about that you're unable to read your text notifications on your Sense. This is odd and just to confirm, have you made sure the Fitbit app is updated? If you have, please give a try to the following:
13:51
05:22
10-13-2020
13:51
05:22
Best Answer10-13-2020 19:25
10-13-2020 19:25
Thank you for your prompt response - I'm not sure I followed your instructions correctly as I think there were a few missing steps, for example, on my phone setting I couldn't find Apps > Fitbit > Force stop.
In any case, with all the fiddling, it seems something has indeed resolved itself and I am now able to read text messages from my Fitbit Sense watch.
Thank you for your help 🙂
10-15-2020
11:28
05:22
10-15-2020
11:28
05:22
Hi @flowerpower_74. I'm glad to see you here in the forums.
You're welcome and thank for trying the steps suggested in my post. It's great that you're able to read your notifications and I hope you continue enjoying the experience with your Sense. By the way, let me invite you to visit the Health & Wellness board where you can make friends and find encouragement from other members to reach your fitness goals. If you need anything else from me, don't hesitate to let me know.
Happy stepping! 😊
Best Answer12-26-2020 09:52
12-26-2020 09:52
Hello I did all the steps in your original post but am also only able to see a notification, but when I touch open....it just says you are all caught up?
12-27-2020
13:36
05:22
12-27-2020
13:36
05:22
Hi @Mabe4922. Welcome on board.
Thanks for the information. Let me explain that the Open option will open the notification on your phone, and automatically remove it from your watch. That's the reason why you're seeing that message since you don't have more notifications pending to check on your watch. To know more about how the notifications work on your Sense, see this help article.
Best Answer12-29-2020 18:19
12-29-2020 18:19
I have tired everything to get my text messages to show up on my sense and will not work.
01-03-2021
14:15
05:21
01-03-2021
14:15
05:21
Hi @Amedina02. Welcome to the Community Forums.
Thanks for your efforts while troubleshooting your Sense. Just to confirm, are you also having an issue to read the text messages on your watch? Or is the issue with the notifications not going through? May I know the model of your phone?
While you've tried some steps, please double check this help article which described some requirements and troubleshooting steps to get the notifications working correctly.
16:46
17:23
LizzyFitbit
01-03-2021
16:46
17:23
LizzyFitbit
Text messages are not going through to my phone. I have an iPhone X. I had this problem with my ionic as well.
Faith: It does not make things Easy it makes them Possible.
Luke 1:37
Moderator Edit: Personal info removed
Best Answer01-04-2021 12:48
01-04-2021 12:48
This helped a lot thank you. For folks on an Android device using Message+ app from Verizon you will need to ensure you privacy settings are turned on enabling preview otherwise you will not see them on the sense. I figured this out by reverting to Samsung messaging and preview was enabled. Check there first.
01-07-2021 10:43
01-07-2021 10:43
Hi justmike5500,
This is what fixed my issue. Thank you!
10:55
05:21
01-07-2021
10:55
05:21
Hi @Amedina02, it's good to see you here again. @justmike5500 and @Kev83, welcome on board.
@Amedina02, thanks for replying back with more details about this matter. Because you have an iPhone, please go to your phone's settings, tap Notifications and make sure Show Previews is set to Always or When Unlocked for Messages and any other preferred app. Also, verify there is a check mark below Notifications Center. Once that is done, try receiving a text message notifications to monitor your Sense.
@justmike5500, thanks for the great suggestions shared in this thread and I'm glad they worked for you and @Kev83. I'm sure your posts will help many other members experiencing similar issues with their watches and Android phones.
Best Answer02-28-2021 13:19
02-28-2021 13:19
I'm having this exact issue on my sense. I get the vibration and a super, super quick preview on my sense when I get a text message. (I'm using Message+ from Verizon on my Galaxy 20+). However, if I swipe down to actually read the message, there's nothing there and it just says I'm all caught up. I have done all these suggestions to no avail:
-Verified in message+ app that previews are shown.
-rebooted app after following sequence to force stop and unpair from bluetooth
-made sure all settings are correct and updated.
I'm getting the notification, but opening it just erases it and I can't read the message on the fitbit itself.
What to do now?
Best Answer02-28-2021 13:35
02-28-2021 13:35
Me too. Very frustrating.
Best Answer02-28-2021 13:51
02-28-2021 13:51
I would make sure notifactions are enabled. Definately do the reboot instructions. You may also want to try changng back to the Samsung message app as default and do a test.
Best Answer02-28-2021 14:15
02-28-2021 14:15
Best Answer02-28-2021 22:53
02-28-2021 22:53
Check your phone settings when this happens before looking on your watch to see if there is a notification in the status bar on the phone.
If the notification disappears from the status bar there is something going on on the phone thats clearing it, which will clear it off the watch too.
18:55
05:21
03-04-2021
18:55
05:21
Hi @Hlawson828, welcome to the Community Forums. @justmike5500 and @Guy_, thanks for stopping by to help our members.
@Hlawson828, thanks for trying the suggestions shared in this thread. I understand how frustrating this can be and I'm sorry for this inconvenience. @Guy_ has a good point as your Sense will receive any notification that arrives on your phone. Could you please confirm if your Message+ app notification still appears on your phone even if it's not on your watch?
While you've tried some steps, because you have an Android phone I'd suggest you to try the following:
I look forward to your response.
Best Answer12-02-2021 08:43
12-02-2021 08:43
This is a great answer. It helped me too! Thanks
12-05-2021
13:40
05:17
12-05-2021
13:40
05:17
@lricky Welcome to the Community Forums.
You're welcome! I'm glad the steps shared in this thread were of help and thanks to you for your efforts. Let me invite you to visit our Health & Wellness board where you can make more friends, find great tips and start your own topics.
