03-25-2021
11:40
06:44
WilsonFitbit
03-25-2021
11:40
06:44
WilsonFitbit
Brought a new sense today and it's not giving me a 4 digit number to sync phone and watch. I've tried everything. Any suggestions? The screen the sense shows is like a calculator with lines instead of a number
Hello @SunsetRunner Welcome to the community forums! @SunsetRunner It's great to see you around and thanks for your input!
Thank you very much for the troubleshooting steps you've tried prior to posting! If the inconvenience persists, I would suggest restarting your Sense by following the steps here: How do I restart my Fitbit device? And then try to perform the setup process one more time. If this is still not possible, please check Why can't I set up my Fitbit device?
Hope this helps!
Hope you're able to use your new tracker soon Kimmy! In *case* the issue remains after @WilsonFitbit suggestion, it's possible to contact the support team of Fitbit as @SunsetRunner recommended.
Since mentioning you've recently purchased the tracker, it's also possible to exchange at the store of purchase with receipt. Possible calling the store first where it's purchased, so they can set another aside if they do that.
Best Wishes
