10-20-2023
14:43
09:22
CrisVillaFitbit
10-20-2023
14:43
09:22
CrisVillaFitbit
The hard piece that's inserted in one end of Sense watchband got stuck in the watch. I was able to easily pull it out of the watch with bull nose pliers. They work well because I could clamp down on the whole width of the piece and pull. I hope this will help the so many others who had this happen. Why is the band made a flimsy part like this? Now, how do I secure it back into the watch band so it stays in? If glue, what kind?
Moderator edit: edited title to clarity
Hi, @flowergirl I am glad to see you around.
Thanks for the steps taken with your Sense's wristband, I'm sure this will help other users. Moving on, can you confirm if you see any damage on the band or does it look normal? I recommend you to check this help article on how to wear your band, if you haven't done so.
