03-03-2021
11:29
11:05
03-03-2021
11:29
11:05
Any word on when Fitbit delivers on their promise to deliver to the rest of the world early 2021?
Does anyone know if that will be a server side switch on their side or if it'll require a FW update?
Best Answer03-03-2021 15:18
03-03-2021 15:18
I agree with this. Fitbit promises. Somehow not visible:
03-04-2021 08:30
03-04-2021 08:30
hi @Deechte ,
hi @R.M,
If you can't wait for the launch, you can activate Google Assistant right now.
Enclosed is a short tutorial with a few screenshots:
Done. You can already use Google Assistant in regions where it is not supported today. In English only, of course.
03-04-2021 10:04
03-04-2021 10:04
Hi @sancho90 , yes I'm fully aware of that. But I really don't feel like talking English. Sorry, hope it didn't take you much time to write all this down
03-04-2021 10:28
03-04-2021 10:28
@Deechte don't worry, maybe this guidance will help other users 😉
Even when Google Assistant will be supported, any time line for verbal replies? Right now only written answers as we had before with Alexa.
Best Answer03-04-2021 10:44
03-04-2021 10:44
Hi, @sancho90,
Thanks for the suggestion - I knew. This is not a solution, but as the Russian saying "crutches (shamanism with drums)", when you need to add something else yourself and when the manufacturer of the product cuts into you. This is Fitbit Sense sells the same everywhere and if it is different then call it another model to make it clear then that it is an incomplete product with other iron components like Fitbit Sense Lite.
Best Answer03-19-2021 03:14 - edited 03-23-2021 06:33
I'm willing to wait a few years for Google Assistant to be a good product. I do not want to use a crude product like Chinese helpers. Google Assistant is used by young Internet users. I recently read an article https://softwaretested.com/technology/the-two-sides-of-using-internet-by-a-student/ about the Internet preferences of young users. Voice search and intuitive collections of information are the engines of the modern Internet.
04-20-2021 06:06
04-20-2021 06:06
thanks for the info
Best Answer05-22-2021 02:10
05-22-2021 02:10
I tried this a couple of times but it does not work for the Netherlands. It said: the language of your region is not yet supported on your Sense.
After a search I learned that you have to change your country in your google account to US. But you can change your country only once a year. So if I do that i'm stuck on the US settings for a year.
