07-14-2019
20:45
13:15
AndreaFitbit
07-14-2019
20:45
13:15
AndreaFitbit
Can someone please explain Sleep Score to me
Moderator edit: Updated subject for clarity.
02-13-2020 10:51
02-13-2020 10:51
Just in case anyone's interested--my "sleep score" went up dramatically by simply moving the watch to the palm side of my wrist at bedtime, from 60's or low 70's each night to consistent mid 80's-- and I'm a short sleeper between 5 and 6 hours every night. I do have consistent sleep schedule: 12:15 am till 6:15 am daily.
02-21-2020 21:53
02-21-2020 21:53
I don’t understand why my sleep score has dropped when all 3 stages have an increased score? Plus I slept for longer,?
02-22-2020 01:00
02-22-2020 01:00
@ZenaLouise : longer time spent asleep doesn’t automatically/always translate into a higher total sleep score, as you can see illustrated in this other post.
Dominique | Finland
05-19-2020 10:30
05-19-2020 10:30
I'm 36 years old and for some reason it always seems like the better sleep score I get, the more tired I am?
For example I usually get around 6ish hours of sleep a night (I know that's not good), however last night I got a solid 7 hours, with a sleep score of 81 and I'm more tired than usual!!??
05-19-2020 15:08
05-19-2020 15:08
05-19-2020 15:19
05-19-2020 15:19
05-19-2020 23:10
05-19-2020 23:10
05-23-2020 17:45
05-23-2020 17:45
Here is an interesting article from the Scientific American. It makes a strong case for why the SSS (Stupid Sleep Score) is just... well just.... so stupid!
https://www.scientificamerican.com/article/an-unusual-cure-for-not-enough-sleep/
06-11-2020 05:47
06-11-2020 05:47
This is can not be the best answer. It isn't an answer.
The score is the score, based on scores... uh thanks
But what does it mean? What are the individual scores? How does getting not enough sleep give you a high score? So need the scales being used, how its weighted. Because it just sounds random and not quantifiable.
Haven't found any information on this yet.
08-20-2020 10:05
08-20-2020 10:05
A long sleep with little or no REM or deep sleep won't get you a very good score. Yes, you were asleep but maybe something you ate or something in your sleep environment prevented your body from getting the deeper sleep. On the other hand, a short sleep with a ton of REM and deep sleep will get you a good score. My guess is their sleep score algorithm heavily weighs REM and deep sleep over sleep duration.
08-20-2020 10:18 - edited 08-20-2020 10:19
My Fitbit is a charge HR---too old to give me any type of sleep score. It does not measure REM at all, just asleep and restless. Hence the fact I always have a zero sleep score. For a while it did not give me my average sleep per week but I noticed several weeks ago that that was back. Thank you, Fitbit for listening to your customers for the average sleep per week.
08-20-2020 10:34
08-20-2020 10:34
08-24-2020 01:14
08-24-2020 01:14
Thank you SteveH for explaining that. I’m new to Fitbit and was very puzzled by my sleep score total after more than 9 hours sleep! I was wondering how on earth that came out as ‘good’. I can see now now that my erratic breathing brought the score down- although I have no idea how to fix that.
12-02-2020 22:19
12-02-2020 22:19
I think the sleep score is a joke and Fitbit is having a laugh. Last night I slept for 6:45 for a score of 72. I woke up feeling relatively refreshed. However, the night before, I slept for 3:38, for a score of 75. What the...? I felt terrible all day. How can you sleep twice as long for a lower sleep score? Last night, my REM and Deep times were pretty good - 1:11 and 1:23, as opposed to 0:58 and 0:35 and I got a 22 out of 25 for Restoration - 97% below resting heart rate. Something doesn’t make sense here.
My Deep/REM scores were identical on the two nights, which is ridiculous. But more ridiculous is my Time Asleep score, which was 34/50 for 3:38, and only 29/50 for 6:45. Fitbit seems to give a wildly disproportionate weighting to time awake. Because last night I woke up and it took me a while to fall back asleep, I got a much lower sleep score. That makes no sense, because I still slept over 3 hours more.
To illustrate my point about time awake: the previous night (ie. 3 nights ago) I scored only 70 for 6:15 total sleep. But, on that night I was awake for even longer so Fitbit broke my sleep into 2 parts, and I had to manually merge them. Before I merged them, the first sleep period was about 4 hours, and...wait for it...my sleep score was 75!! So by going back to sleep for a couple of hours, my score dropped by 5 points, only because I was awake longer.
12-02-2020 23:34
12-02-2020 23:34
“The more you sleep, the better your score”
Except this is not true.
As I wrote in my previous reply to the OP, where I provided real examples, getting more sleep can result in a lower sleep score. This seems counterintuitive. The reason seems to be that the longer you are awake, the worse your sleep score, even if you sleep longer. If it were me, I would prioritise Time Asleep over time awake. A longer “time awake” might suggest a lower quality of sleep, but in my case I was awake for a block of time, and actually slept well for the time I was asleep, and I had decent Deep and REM times, and an excellent Restoration score. It makes zero sense that I could sleep twice as long, have better Deep and REM times, and get a lower score, or that I could fall back asleep for a couple of hours of quality sleep, and my sleep score goes down.
I would prefer it if “the longer you sleep, the better your score”, were actually true, and I wish Fitbit would address this.
12-04-2020 09:17
12-04-2020 09:17
I’m also confused! I have a sleep goal of 6.5 hours; I slept just over 7 hrs last night, and only got a score of 43 out of 50?
12-04-2020 12:43
12-04-2020 12:43
12-05-2020 18:40
12-05-2020 18:40
Yeah, they also forced a clock feature on mine. I don't want to know what time it is but I can't help but to accidentally see the clock sometimes when using the Fitbit.
12-05-2020 18:48
12-05-2020 18:48
Id loved to tell you but it doesnt work for me 😞
01-22-2021 04:19
01-22-2021 04:19
