There are no settings for the clock - it is set automatically whenever you sync. Is your fitbit syncing ok?
The other thing to check is that your timezone is set correctly in your profile settings at: https://www.fitbit.com/user/profile/edit
Fancy seeing you here @Bartonseagrave. Welcome to the Forums! I hope you could fix the time on your Fitbit. You can also check that information in the Fitbit App, under Account > Advance Settings > Time Zone.
If you have time, please check our Discussions board where you will find other members sharing their experiences and tips for an active lifestyle, you might be interested in this topics: Marathon Training or How do you break out of your sedentary lifestyle?
I'll be around in case you need anything else! ![]()
Hey there @Bartonseagrave! Hope you're doing well, and enjoying some healthy activities! ![]()
I noticed that you didn't required more help, if you found the solution in any of the previous posts; I invite you to mark this post as the solution. Marking posts as solutions is a great way of thanking another community member while also highlighting their solution so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions here.
Happy stepping! ![]()
