01-24-2018 17:35
01-24-2018 17:35
Hey can anyone help ?
I just got a surge and I sweat a lot when I workout and I do hike a lot too so now I have condensation under the screen. I have tried rice I have tried hairdryer radiator you name it I tried it. As long the screen is warm everything is fine but as soon as i have it around my wrist and the screen cools .... BOOM.... the condensation is back. It’s now in a container with uncooked rice in my hot press for day two in a row. Is there anything else I can try ?
Best Answer01-25-2018 03:11
01-25-2018 03:11
How long have you had your surge? If it less than 1 year contract support as they should replace your surge. Unfortunately if its over a year old then there isn't much you can do except buy a new tracker ( not a surge as they have been discontinued ) maybe check out other competitors and read the forums before purchasing anything. Good luck!
Best Answer01-25-2018 06:42
01-25-2018 06:42
Best Answer01-25-2018 06:43
01-25-2018 06:43
Thank you so much for your help I think I am out of luck as the surge was a gift so I don’t have prove of purchase. 😕
thanks again so much tho
Best Answer01-26-2018 05:54
01-26-2018 05:54
If it's less than 1 year fitbit support should be able to tell when it was registered to your account, you just need to tell them it was a gift.
