12-20-2017 06:01
12-20-2017 06:01
I received my Fitbit surge 2 days ago. Charged it up overnight. Started to configure in the morning. Got all the way through to updating the tracked and I get this message “ fbbluetootherrordoimain8 “. Any suggestions?
Best Answer12-21-2017 03:46
12-21-2017 03:46
Hi @deneaujohn
You posted on the Charge forum, so this is how I fixed my Charge.
Go to your Bluetooth settings on your iPhone and find your tracker, tap the (!) exclamation point and select "Forget this device".
To pair your tracker's Bluetooth from the Fitbit app do the following:
From your mobile Dashboard tap the Account icon
Tap your tracker's picture on the left side
Tap Notifications; move the slide over till it turns green, then a pop-up message should appear requesting permission to set up your tracker to your iPhone's Bluetooth
Tap Pair when prompted too
Let the download complete, be patience.
Now do a sync
More info on how I got it to complete the download
https://help.fitbit.com/articles/en_US/Help_article/2047
Forget your device video
https://www.imore.com/how-to-fix-bluetooth-iphone-ipad
Syncing Article
https://help.fitbit.com/articles/en_US/Help_article/1866/?l=en_US&fs=RelatedArticle
Also, I'll move your post over to the Surge forum
@ACG
ALAN | VAN,B.C. Canada Community Council Member
Versa, Charge, Charge HR, Ionic, Ace, Aria 2 scale, Flyer headphones - iOS
Click here Fitbit help for more solutions
Best Answer12-28-2017 00:41
12-28-2017 00:41
Thank you Great instructions and my Charger started working after step 1! You are a legend my friend!! Happy running and thanks again for your suggestions
Best Answer12-28-2017 02:18
12-28-2017 02:18
Hi, @Billeebee I have marked @ACG's answer as the solution, as you stated his instructions worked for you. Marking posts as solutions helps other users quickly find the information they are looking for.
Happy New Year!
Best Answer12-28-2017 08:28
12-28-2017 08:28
Please Un-mark this issue as solved as this is not a fix for the surge. Thank You
Best Answer12-28-2017 08:38
12-28-2017 08:38
Hi, @Kawigreen, wjat issues are you having with your Surge? Someone may be able to help.
Best Answer12-28-2017 08:54
12-28-2017 08:54
Nothing I did worked. Contacted Fitbit thru there chat and a replacement is on it's way.
Best Answer12-28-2017 09:07 - edited 12-28-2017 09:09
okay, I see that it did not work for you as the original person who posted.
Best Answer12-29-2017 10:10
12-29-2017 10:10
Same issues every one is having between the surge and Apple products. Upon adding the surge to the app you get a error 24 and then it tells you to update your surge and you get an error 8. I contacted support and they said there was no fix for this yet and there techs where working it. There only idea was to use an android device.
Best Answer12-29-2017 12:25
12-29-2017 12:25
If there only solution is to say buy an android, then I believe we should be receiving a refund for the products we purchased for use on our Apple products.
Best Answer12-29-2017 12:28
12-29-2017 12:28
Received the new Surge in the mail yesterday 12/28/17 Charged the battery, went to connect to my iPhone, error 24 then and error 8. ( same thing as the first one ) Chatted with Fitbit online and there solution was to " try again in a few days, it's a software problem " ?????
Best Answer12-29-2017 16:31 - edited 12-29-2017 16:31
Hi Everyone - We are currently investing reports of Surge users unable to set up their tracker on iOS, seeing: Error 24, followed by Error Domain Error 8. For updates, please check out this thread on the iOS board. Thanks for your reports and we do apologize for the inconvenience. I'll be closing this thread for further comments, please direct any questions to the above-mentioned thread.
Actively managing your weight? Find accountability buddies on the Manage Weight board
