05-02-2017
05:10
11:17
YojanaFitbit
05-02-2017
05:10
11:17
YojanaFitbit
Fitbit Surge
I have suggested a few small modifications to the fitbit sleep quality recording software. After these large improvements of the software the User Manual could look like this:
User Manual
(Suggested by Svend Lund).
Fitbit sleep quality (Fitbit Surge)
1. Open fitbit app on your PC. Select: Log sleep
Now the following two activity buttons are displayed on your screen:
sleep log normal (Which shows the normal set bed-time/wake-up time)
and
sleep log special (Which shows the special set bedtime/wake-up time)
____________
2. If you want to display your sleep quality during your normal sleep period:
Select the activity button:sleep log normal
and the sleep activities are immediately displayed on the screen.
____________
Select the activity button:sleep log special and the sleep activities are immediately
______________
periods respectively.
You can any time change the specified values as often as needed.
You will always be able to display the sleep quality for your sleep
during the last 24 hours.
Moderator edit: Format. Clarified subject.
A warm welcome to our Fitbit Community family @SvendLund! ![]()
Wow! Really good feedback, I'll definitely pass along this information to our team. Thanks a million for taking the time to check this options. I'm sure your comments will be of great help to have a better idea of the user perspective. Hope to see you around more often and keep looking around, I'm sure you will find helpful information here!
I dont' know if you're familiar with our Discussions board, there is a really good chance for you to like it. In case that you haven't do so, check it out! You might be interested in these topics: Marathon Training or How do you break out of your sedentary lifestyle?
See you around! ![]()
