01-13-2016 21:29
01-13-2016 21:29
I just encountered one issue today. When i tried to turn on my Surge Bluetooth Classic, my device will automatically reboot. I tried it for 3 times and it keeps on rebooting the device. I shut down and start again but didn't help to resolve the problem. Anyone facing the same problem here? Help needed! Thanks.
Regards
Kelvin
11-29-2017 10:45
11-29-2017 10:45
Hey there @PG_Tan, thanks for getting back.
Since those steps didn't solve the issue you're having, I've requested to our Support team to create a case on your behalf. You should soon receive an email from Customer Support at the email you used to register with the Community forums.
Let me know if you have questions about it.
11-29-2017 15:49
11-29-2017 15:49
I received email showed the status is resolved.
I did not even get any help from the customer support and the team closed the case without further investigation or debugging. It is very awkward in this support system.
12-01-2017 08:06 - edited 12-01-2017 08:26
Thanks for letting me know that information, sorry for the misunderstanding I will check what happened there and I'll reply back to you.
Thanks for your understanding.
05-01-2018 19:48 - edited 05-01-2018 19:52
I do, as many other users who have not been successful in solving the problem either.
05-02-2018 06:58
05-02-2018 06:58
any solution to turn off bluetooth classic?
05-07-2018 15:11
05-07-2018 15:11
I also facing the same problem
05-07-2018 15:18
05-07-2018 15:18
05-10-2018 10:07
05-10-2018 10:07
Hi @Aleagena and @zzjoe thanks for getting back. @yazidsharll welcome to the Forums!
Sorry for the issues your having with your Fitbit Surge, we haven't received additional information about this issue. But thanks @zzjoe for sharing those steps. Your feedback is really appreciated. Please let me know if you need me to request a case with our support team, so they can check your options.
Thank you for your understanding.
05-10-2018 19:06
05-10-2018 19:06
05-11-2018 01:21
05-11-2018 01:21
08-14-2018 14:20
08-14-2018 14:20
There's something both incredibly satisfying and horribly frustrating to find so many other people with the same problem. I'm on fourth Surge unit, with three replacements under warranty because of strap issues (either splitting or peeling away from the unit). And each unit had also some sort of Bluetooth problem after a few months' use as well. My current unit will not synch, and neither my iPhone 6 nor my Mac will now even recognise its existence as a Bluetooth device. I tried removing it to set it up again, and I can't even do that any more. The only good thing is that the strap hasn't broken yet. Time to give up and move on to piece of kit I can have more confidence in, I fear. Shame.
08-15-2018 06:27
08-15-2018 06:27
08-15-2018 12:40
08-15-2018 12:40
08-15-2018 17:24
08-15-2018 17:24
08-15-2018 18:14 - edited 08-15-2018 18:18
Sorry double posted
08-15-2018 18:16
08-15-2018 18:16
I got the ionic, too. It’s pretty nice and have no issues as long as app is up to date. Surge is garbage. .
08-16-2018 14:31
08-16-2018 14:31
Hi everybody! Thanks for posting your inquiry here in the Forums!
As mentioned before if you're having issues with the Bluetooth Classic option in your Surge. As I mentioned before please restart your tracker a couple of times, update your Fitbit App and phone to the latest version. Access to the Bluetooth settings of your mobile device to delete Fitbit Surge from there. Reboot your Bluetooth once again and try to reconnect your Fitbit as a replacement device from the Fitbit App:
iOS: Account > Set up a device > Choose the option replace
Android: Main Menu > Devices > Tap on the (+) sign in the upper right corner > Replace your tracker
PC: Open Fitbit Connect > Set up a new device > Existing user > Replace tracker
(Surge should connect with the Fitbit App / Bluetooth Classic is used for Music Control only) If you're having syncing issues try the restart one more time and check this syncing steps.
Once your Surge is syncing you can try to use the Music Control option; this should be able to switch from Off to On or Pair. You can see this master post from@DerrickFitbit to use the feature Music Control again.
If you already try this option, please let me know so I can check the next step for you.
Let know is this helps!
01-11-2019 19:03
01-11-2019 19:03
I've faced similar issue more than a year ago, but brushed it aside as I don't actually need it to sync with app or pc. However, I've recently signed up for Singapore's National Steps Challenge, and it requires me to sync with a step tracker. And so I need it to sync badly now!
I've tried everything suggested by users here, and then wrote to Fitbit, who suggested the following:
Yes, I've tried them, still it doesn't work. I shall reiterate the issue faced by all of us here: Surge can't turn its bluetooth from "off" to "on/pair". It will hang and restart everytime I do so. Hope the Fitbit team would acknowledge this issue and is working on it. Or maybe it doesn't, since Surge has been discontinued.
01-14-2020 14:52
01-14-2020 14:52
Your nice words sadly aren’t fixing anything. You are king a great job but fit bit needs to sort this and
A. Just stay it doesn’t work or like most tech companies have a comparability graf showing what device and its features work with different apple, android or google devices.
B. Give an easy video tutorial for fixing the problems with this exspensive device.
C. Time is valuable and the time Fitbit customers have wasted trying fix a clunky product is **ahem**.
01-14-2020 14:53
01-14-2020 14:53
Yes GARMAN next time for me.
