05-10-2018 01:29
05-10-2018 01:29
Logged a bike ride this morning; all fine on the Fitbit app; it usually takes a few minutes to appear on Strava but three hours later it's still not appeared.
I don't want to disconnect and re-connect Strava as I think I've hit several PB's and it will loose the ride; any ideas?
05-25-2018 09:44 - edited 05-25-2018 09:46
Hi @WillBiltcliffe! I'm glad to see you here in the Forums, your comments are very important for us. @Lburns welcome!
Good to know that you're using your tracker to get healthier. Thanks for posting your question here. As you already tried the those steps I would consider contacting Strava Support directly; take a look of the Resources for the Strava App. They are really helpful. Remember that you need to confirm that your tracker is properly syncing.
BTW thanks @SteveH for jumping in.
Keep me posted on the resolution!
05-10-2018 01:34
05-10-2018 01:34
There's an ongoing issue with syncing to Strava. Keep an eye on the following thread which has the latest updates from fitbit:
05-10-2018 01:35
05-10-2018 01:35
Hi, mine is doing the exact same thing. I went for a run last night and it took about 4 hours to show on Strava. I went for a run this morning and 2 hours later it still isn’t showing on Strava. I’m assuming there must be issues?!
05-10-2018 01:45
05-10-2018 01:45
Thanks for the replies; glad it's not just me. I wouldn't mind if it was a bad ride but I love my medals!
05-16-2018 11:58
05-16-2018 11:58
@Lburns please read the post above yours .
