01-03-2016 11:27
01-03-2016 11:27
01-03-2016 11:44
01-03-2016 11:44
@MartinIkaika , has it ever synced? Are there any other bluetooth devices nearby that could be confusing the signal? The usual basic troubleshooting advice is to try toggling bluetooth off and then toggling it on again. You might also want to turn your Surge off and then on again. Turning Surge off and then on: Press and hold the Home and Select buttons (left and bottom right) on your Fitbit Surge™ for 10 to 15 seconds, until you see the screen flash or start to dim. After your screen turns completely off, wait 10 seconds and press the Home button to turn your Surge back on.
01-03-2016 11:44
01-03-2016 11:44
01-08-2016 13:14
01-08-2016 13:14
Thank you for joining us @MartinIkaika! Besides @Julia_G's advice, you can try to set up your Surge as a new device again with your computer, iOS and Android device. If you're using a mobile device you can also check if you have your "All Day Sync" option enabled.
Good luck!
01-10-2016 11:41
01-10-2016 11:41
Best Answer01-10-2016 14:03
01-10-2016 14:03
Best Answer03-29-2016 16:28
03-29-2016 16:28
Hello there @MartinIkaika, I'd like to know if your battery is lasting as it should. If that's the case, feel free to share the steps you took to resolve this. I'm pretty sure a lot of friends will appreciate it.
04-03-2016 09:01
04-03-2016 09:01
The surge will sync via the cable...it is not just a charge cable....
Best Answer04-03-2016 09:07
04-03-2016 09:07
@gaz2387 wrote:The surge will sync via the cable...it is not just a charge cable....
it is just a charge cable.
Best Answer04-04-2016 16:13
04-04-2016 16:13
Hello there @gaz2387! The charging cable is for charging purposes only. I'd like to know if your Surge syncs only when it is plugged. I'd recommend restarting your Surge. Once you're ready to sync, place the tracker near the dongle to check if this works.
Let me know how it goes.
04-05-2016 00:02 - edited 04-05-2016 00:16
I can promise you, and there is another thread on this forum that says the same thing.
(See https://community.fitbit.com/t5/Surge/Surge-Sync-through-Charge-Cable-in-PC/m-p/695962/highlight/tru...
Fitbit connect will show "Surge Connected" when the "charging" cable is plugged in.
This allows the Surge to sync WITHOUT the dongle.
my Surge will only sync this way - I have been through restarting my Surge, and just turning it off and back on - however it will never connect wirelessly - the ONLY time it syncs is when the charging cable is used - with or without the dongle.
04-07-2016 10:46
04-07-2016 10:46
This is really interesting @gaz2387! I'd like to know if you have a mobile device nearby your tracker. If you have downloaded the app, your tracker will constantly sync and this transfers the information to your Dashboard. Let me know if this is not the case.
04-07-2016 11:32
04-07-2016 11:32
Best Answer04-10-2016 02:22
04-10-2016 02:22
same here...
I tried to set up my new surge yesterday and plugged it in my laptop. BT is never enabled on my laptop and still it connected. It even started downloading the update but gave an error after a few seconds. No wireless connection possible, but still the app found my Surge.
Best Answer05-01-2016 19:05
05-01-2016 19:05
05-07-2016 07:36
05-07-2016 07:36
05-08-2016 12:09
05-08-2016 12:09
I give up. I have tried everything several times and yet this piece of crap will still not sync. I have removed the app from my mobile devices, there is no bluetooth in the house, let alone near the Fitbit, I have reinstalled and reinstalled until I am blue in the face, I have tried to register it as a new device. Nothing works ... it is going in the garbage. I'm done.
05-08-2016 12:10
05-08-2016 12:10
Why can't Fitbit offer any advice? Why do you wait for us to find a solution and tell everone?
05-08-2016 15:29
05-08-2016 15:29
05-15-2016 10:39
05-15-2016 10:39
Bought a fitbit surge a few months ago. Since than had a lot of problems with synchronizing with my iMac.
Turning it off/on, re-installing, ... sometimes it synchronizes sometimes it doesn't. No idea why. Most of the time it says that i have to put the fitbit nearer, but it is a 30cm from the dongle ....:-(, but it keeps on searching for my watch (with full battery)
I'd really like to have a solution that fits, while the actual situation is soooo disappointing.
What is the best way to solve the synchronising issue (synchronising with an iMac) ?
Best Answer05-15-2016 10:45
05-15-2016 10:45
