08-23-2016 02:40
08-23-2016 02:40
Result from Gps is not visible on my Iphone, it´s just buffering .
08-23-2016 15:31
08-23-2016 15:31
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
09-02-2016
05:04
13:26
AndreaFitbit
09-02-2016
05:04
13:26
AndreaFitbit
Hi again, my problem is that after an exercise for example a hike for
several hours I can't see the track on the dashboard in my iPhone. The
symbol for buffering is showing but no result on the map.
I hope you understand my problem now, if I could write in Swedish it would
be much easier.
Best regards
Ulla
Moderator edit: removed personal information.
09-04-2016 05:15
09-04-2016 05:15
@ullas Welcome to our Community! Have you tried restarting your phone? Also you could try logging out and back into the app. Also could you share a screenshot of what you see on your phone?
Let me know how it goes!
09-05-2016
00:42
07:02
HelenaFitbit
09-05-2016
00:42
07:02
HelenaFitbit
Logging in and out into the app and restarting the phone doesn't work. Can the length of the exercice have something to do with the problems.
Moderator edit: Removed personal information.
09-09-2016 11:13
09-09-2016 11:13
@ullas Thanks for the update! How long was the exercise? Let's dig a little deeper to find solutions here! Also remember that if your tracker's GPS signal is being blocked, either because you're underground, near many tall buildings, or as a result of atmospheric effects then GPS will not work. Thus, whereas GPS gives you a more accurate measure of distance than step counting alone, the actual accuracy depends on both your environment and the weather.
A screenshot would result extremely helpful just like @AlvaroFitbit requested. I'll be looking forward to your new comments!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
09-10-2016
03:04
13:40
MariamV
09-10-2016
03:04
13:40
MariamV
Hi
The exercice took place up in the mountains. The pictures shows:
No 1: This's what my IPhone 6 shows
No 2: This's the result from the hike
No 3: This's what I want to see in my phone and I can see it in my computer
but
why can't see it in my IPhone?
Can the length of the hike more than six hours have something to do with
the problem?
Best regards
Ulla
09-11-2016 13:47
09-11-2016 13:47
@ullas thanks for the update! I can't view the pictures. Would you please be so kind to post them again. In doubt, please review this post by @SunsetRunner on how to post a picture in the forums. Hope this helps and I'll be looking forward to your new comments!
09-13-2016 03:31
09-13-2016 03:31
