02-24-2017 06:11 - last edited on 02-24-2017 12:03 by YojanaFitbit
How do i use this fitbit surge for cycling ?
Moderator edit: Clarified subject.
02-24-2017 12:02
02-24-2017 12:02
A warm welcome to our Fitbit Community family @Basher67! I'll be more than glad to help you with this. You can use the Shortcut in your Fitbit Surge screen "Bike" to use the GPS while biking. This is the MultiSport feature. For more details about it take a look of this post that explains how your can track activities using GPS.
You can edit your Shorcuts of your Surge by going to your Fitbit.com Dashboard. After each activity remember to sync your information and you will see the exercise in your Fitbit App under the tile "Track exercise".
Hope this helps!
02-24-2017 12:02
02-24-2017 12:02
Hope this helps!
11-09-2018 00:17
11-09-2018 00:17
"bike" is not an option on my surge. How do I get it there. ?
11-14-2018 08:43
11-14-2018 08:43
Thanks for popping by the forums @BRover, welcome!
You can add the new exercises to your Surge shortcuts by going to your phone in the Fitbit App > Surge > Shortcuts. Or in your Fitbit.com Dashboard in a computer, under Settings > Surge > Exercise Shortcuts.
In this case your Bike activities will include a map with the stats of your route.
I'll be around!
10-11-2019 18:34
10-11-2019 18:34
cycling is not displayed as an option
10-11-2019 21:29
10-11-2019 21:29
Do not search for cycling, instead surch for bike. If it is not in the menu, you can add it through the app. Explained in the post above yours.
