03-22-2017
02:30
11:10
YojanaFitbit
03-22-2017
02:30
11:10
YojanaFitbit
Hallo I bought 15-6-2016 a Fitbit surge, but last weekend it stopped loading. Can you help me to a contact page ?
Moderator edit: Clarified subject.
03-22-2017 09:02 - edited 03-22-2017 09:03
Halo @Tiela thanks for stopping by! Thank you for your participation in the forums! ![]()
Good to know that you've a loyal customer since that date! As @WendyB said, restating the Surge a couple of times would be a good idea. Clean the charging contacts on the back of your Surge. These contacts can become obstructed by microscopic dirt or debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this may damage the plating and result in corrosion.
Please try to reconnected to your Fitbit Account by following the Setup steps for different platforms. And always check the syncing requirements to properly connect in case you changed your mobile device.
Hope this helps! ![]()
Best Answer03-22-2017 03:01
03-22-2017 03:01
Welcome to the forums!
Try a restart. Do it at least 3 times.
Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
If that doesn't help
Contact Support
http://help.fitbit.com/?cu=1
I'm sure support will take care of you
Wendy | CA | Moto G6 Android
Best Answer03-22-2017 10:31
03-22-2017 10:31
03-23-2017 11:09
03-23-2017 11:09
Hi @Tiela! Great job! Thanks for let me know that it worked and for marking this post as an Accepted Solution! ![]()
I'm glad to know that you're back on track! I wanted to take the opportunity to invite you to our Discussions board, there is a really good chance for you to like it. In case that you haven't do so, check it out! You might be interested in these topics: Saturday Humor or What is the most interesting place that you have walked run?
Happy stepping! ![]()
