01-14-2016 09:52
01-14-2016 09:52
Best Answer01-16-2016 09:17
01-16-2016 09:17
Welcome to the Fitbit community @Scott81368! I hope you're doing great!
Allow me to help, just as @SunsetRunner said indeed you have music control on your Surge, take a look at this article in order to set it up.
Hope it helps!
01-15-2016 06:26
01-15-2016 06:26
You need to be more specific what isn't working.
Have you set it up? Have you paired the Surge and phone using Bluetooth (Classic)? Is the Bluetoot (Classic) turned on on the Surge? What music app are you using? Have you double-pressed the :Home: button (the side with the single button) to bring up the controls?
FWIW - it works perfectly on my Samsung Galaxy S6.
01-16-2016 09:17
01-16-2016 09:17
Hope it helps!
