02-19-2018
12:19
07:40
YojanaFitbit
02-19-2018
12:19
07:40
YojanaFitbit
anyone know how to set the time on a Surge?
02-23-2018 07:38
02-23-2018 07:38
It's great to see that you've visited the Fitbit Community @afterfive, welcome! Thanks @WendyB! ![]()
You can also check these other options to troubleshoot the time zone on your Surge.
If 's suggestion helped you i invite you to mark her post as the solution. Marking posts as solutions is a great way of thanking another community member, while also highlighting their solution; so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions.
Let me know if you have questions.
02-19-2018 13:13
02-19-2018 13:13
Welcome to the forums!
On the computer: Go to the Dashboard and click on the gear and choose settings from the drop down. Scroll down to time zone Change it to s different one. Sync it. Go back in and change it to the correct one and sync again
Phone: Click on account upper top right looks like an envelope. Scroll down to advanced settings and do the same as above
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
02-23-2018 07:38
02-23-2018 07:38
