10-24-2016 14:09
10-24-2016 14:09
Best Answer10-31-2016 12:08
10-31-2016 12:08
Welcome to the Community @Sdubberben! Have you checked if your tracker is correctly syncing? To check if your tracker is syncing in your iOS app, go to account and tap on the picture of your tracker. Under the name of your tracker you can see the last time it synced.
If it hasn't synced currently, please check this post about the Syncing Troubleshoot for iOS Devices.
After confirming that your tracker is syncing, you can check your steps on your workplace challenge. If they haven't updated please get in touch with your Corporate representative for extra help.
Good luck, keep me posted! 😉
11-07-2016 04:32
11-07-2016 04:32
Hi there @Sdubberben let me give you a warm welcome to our community too. I found my friend @LucyAP replied to your post, but for some reason the reply was posted separately, perhaps a glitch on our Community.
So I took the liberty to merged both posts and if the issue persists, give it a try to her recommendation.
Hope it helps and we will be around if you have more questions.
