02-17-2017 22:44
02-17-2017 22:44
All of a sudden my surge is saying I am in Los Angeles. I have rebooted a couple of times and it will not change back to my Sydney time. I have not travelled I just went to check the time and it was a different Timezone.
Any suggestions?
02-17-2017 23:51
02-17-2017 23:51
On the dashboard click on the gear and go to settings. Scroll down to time zone and change it. It must sync before it takes place.
Wendy | CA | Moto G6 Android
Best Answer02-18-2017 00:17
02-18-2017 00:17
I have tried that numerous times. The app goes automatically to Sydney, but when the surge syncs it changes the app back back to
LA. 😣
Best Answer05-10-2017 22:12
05-10-2017 22:12
I have the same problem with my Alta
Best Answer05-10-2017 22:33
05-10-2017 22:33
05-13-2017 09:50 - edited 05-13-2017 09:51
Hello beautiful, @BarbMNSW! Thanks for the updates and for letting us know what worked for you.
So let me see if I understood you correctly. You were changing in your settings but not syncing your device after? ![]()
When you make any change on your Fitbit account it is important to sync for the changes to save in your device as well.
A warm welcome to out new friend, @stevefocus!
Have you tried to change it back to the correct one by following these instructions? It is better if you do it using a computer, if it is not working with the App.
Please let us know what have you tried so we can further assist you. :}
Best Answer05-13-2017 10:08
05-13-2017 10:08
Yeah I've fixed it now, when I changed time zones on the app it reverted to LA time zone had to change it on my PC. Thanks.
Best Answer05-18-2017 10:36
05-18-2017 10:36
Hello, @stevefocus! It is nice to see you.
Thanks for the updates, I'm glad to hear that you are back on track.
I would love to see you participating a little more, check out our Discussion boards and find your favorite topic.
