It doesn't take me to the menu. It doesn't take me anywhere. I tried the change clock face trick, but it did not help. I've tried the trick on my cell phone using the mobile app, and here at the website. My Surge battery died over the holidays and I recharged but the Home button has not worked since.
Best AnswerHeld the left(home), and the lower right(select) buttons down for 12 seconds. Let go and screen turned off. Waited ten seconds and pressed the home button to turn on. Reset is complete. Then pressed the home button to get to menu. Nothing happened.
I hope you're doing great @SFDonovan! Allow me to help, since you have already tried all of the steps and the issue persists I agree with @chris2121 you should get in touch with the Support Team so they can review your options.
Let me know the outcome!
