01-13-2016 10:24 - last edited on 03-30-2016 09:23 by VivisFitbit
Surge battery died. Plugged in and charged for 3 hours. But still won't turn on. Have only had the Fitbit surge for 1 1/2 months. What is wrong?
01-13-2016 10:27
01-13-2016 10:27
01-14-2016 07:57
01-14-2016 07:57
Welcome to the Fitbit Community @SunsetRunner! It's great to have you here!
I't's good to know that your Surge is working properly know the battery should last at least 7 days if you're using the GPS can last 5 hours or less, you can take a look at this article in order to maximize the battery life.
Hope this helps!
05-20-2016 04:27
05-20-2016 04:27
My Surge will not turn on any ideas ? Help desk diidn't help as they said hold all 3 buttons whist the surge is plugged in via the usb for 15secs. if that does not work but a new one
05-20-2016 05:47
05-20-2016 05:47
It's great to have you here @Nev666! Welcome to the Community!
Let me help you out, in order to perform the restart follow these instructions:
Also double check that your Surge is being charged correctly, I recommend checking this article.
Let me know how it goes, I'll be around .
07-01-2016 05:39
07-01-2016 05:39
Hi. My surge is fully charged and will not turn on. It only works when it is charging,as soon as I unplug the charger it switches off and will not turn back on. I have done what you suggested above and it hasnt worked. I only purchased and set it all up yesterday. Please help,thanks.
07-05-2016 02:29
07-05-2016 02:29
07-22-2016 23:33
07-22-2016 23:33
Oh no not another microsoft - sell you something that doesn't work. just wasted a whole day trying to get my new Surge fitbit to work, just wont turn on - very very disappointed after trying every known fix many times - Looks like its back to the shop on monday!
07-24-2016 10:17
07-24-2016 10:17
im having same trouble as i just got mine also
07-30-2016 08:54
07-30-2016 08:54
I have the same issue. Any ideas how to resolve this?
08-01-2016 02:55
08-01-2016 02:55
02-22-2017 19:06
02-22-2017 19:06
I just got my surge n I charged it for 3 hrs n won't turn on all it shows is the back light. Nothing displays on the screen. It tries to connect with the app cuz it gets to the point where it asks me for the 4 pin code that should show on the surge but nothing displays just the back light when I press the left power button. Some one plz help.
02-23-2017 05:25
02-23-2017 05:25
Hey there @Grumpz! Nice to see you here too. I just replied your other post with some instructions to follow, please follow those steps, and in case you need more help; you can post in this thread or in the other one. Hope you find all you need here in the Forums!
I'll be around!
07-28-2017 10:04
07-28-2017 10:04
I miss placed my fit bit surge for a while. Plugged it into charge it and it's completely charged but will not come on. Can you help me please ?
07-28-2017 10:40
07-28-2017 10:40
It's great to see new users around @Griggskatie65!
Let me help you with your Surge. Please double check that is charged by following the charging best practices then restart it 2 or 3 consecutive times.
Let me know how it goes, I'll be around!
08-02-2017 16:20
08-02-2017 16:20
Thanks MaginFitbit, this reset worked perfectly for me too. Is there any advice or indication as to why the fitbit would appear to be flat/off when fully charged? Are there possible software updates required?
08-03-2017 07:47 - edited 08-03-2017 07:48
Thanks for visiting the Community @norgus!
It's great to hear that you got it sorted out. If you're experiencing any kind of glitch regarding the battery my best advise is to take a look at the charging best practices.
Hope to you posting more often!
10-08-2017 09:43 - last edited on 10-20-2017 09:42 by YojanaFitbit
My fitbit surge battery died (I was sick and forgot to charge it). I have never let my watch's battery die ever before. I have had it plugged in for about 6 hours. No light, or anything is showing. I have tried all the possible above things to start / restart / turn it on....absolutely nothing. No light or anything anywhere...no vibration....nothing! I have not had this watch for very long. (this is my 2nd fitbit surge...1st one I had for a few years...and this current one I have is a replacement from the warrenty from my first watch). I have had no issues or weirdness or glitches with my watch prior to the battery dying (and yes it just naturally died because I forgot to put it on the charger).
10-20-2017 09:52
10-20-2017 09:52
I'm glad to see your comments here in the Forums @Trinty425. Welcome!
This is pretty odd! Please put your Fitbit Surge to charge a couple of minutes and try the restart again while it is connected, this time do it multiple times. If this doesn't work, let me know so I can check with our Support Team to see what other option we have for you.
If any of this steps works please let me know, I'm very interested in helping you out this!
10-20-2017 20:03
10-20-2017 20:03
Has this been resolved?
