02-17-2017 08:06 - edited 02-17-2017 08:09
After a few hours/half day use my Surge starts to switch off various horizontal lines on the display* up to a point where the whole screen goes blank. When I press a button or swipe the glass the screen updates (graphic reappears) but only 'where needed', typically the top and bottom parts of the display stay empy. Background lightining and all measure functions still work normally, just screen refreshing fails.
I can fix this problem temporarily by turning off the device at least for a few minutes, the more it stays turned off (a few hours) the longer the fix holds. So after all I can still use the device but I wonder if there is a known permanent solution for this issue.
Thanks!
*see photo attached
Missing horizontal lines after a few hours of operation
03-25-2017 07:21 - edited 03-31-2017 11:34
I've noticed you are new around @LaszloPrekop, so let me give you a warm welcome to our Community. ![]()
Sorry for the issues with your Surge! Thanks for the steps that you've tried to solve the issue! Keep an eye on your email inbox for next steps!
I'll be around in case that you have questions about it. ![]()
02-17-2017 10:40
02-20-2017 09:06
02-20-2017 09:06
Thanks for the tip, but turning off for a longer period is better than a simple quick restart, right?
Any more ideas? I start to think that the waterproof sealing of the device got damaged over time, so water/sweat gets into the housing and causes poor display connection, so horizontal lines start to fail one by one (again, see original photo attached).
03-26-2017 07:14
03-26-2017 07:14
I have the same problem. all my dashboard vanish but heart rate tracking still work.
what should I do. please suggest me.
Thank
03-31-2017 12:13
03-31-2017 12:13
Thanks for joining us! How you doing @Uttood? ![]()
So glad to see your post! Please restat your Surge a couple of times. How old is your Surge?
If it is more than 6 months old, clean the charging contacts on the back of your Surge. These contacts can become obstructed by microscopic dirt or debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this may damage the plating and result in corrosion.
We recommend plugging your charging cable into a USB port on your computer or other low-energy device. If necessary, you can use a UL-certified USB wall charger. Don't use a USB hub or battery pack to charge, and only use the charging cable that came with your tracker. I'd like to know if you're getting the full battery sign after charging your Surge for 3 hours. Then you can force sync your Surge to see if it is connecting.
Please keep me posted! ![]()
06-20-2017 14:45
06-20-2017 14:45
I'm also seeing this issue with my Fitbit surge. Usually the screen blanks out quicker if I'm tracking a workout. Is there a resolution to this issue. I've been able to confirm through my phone syncing that it is getting a charge.
06-22-2017 09:20 - edited 06-22-2017 09:21
Halo, @Joshua1985 thanks for stopping by! Thank you for your participation in the forums! ![]()
If you keep having issues with the display of your Surge, I'd suggest restart your tracker a couple of times. This is not an expected behavior from your tracker, but it should solve the issue in case that it's a hardware issue.
Please let me know how it works!
06-22-2017 13:04
06-22-2017 13:04
Hi Yojana,
Thanks for getting back to me on this issue! I restarted several times and unfortunately within an hour the issue has occurred again ![]()
06-23-2017 09:13
06-23-2017 09:13
Thanks for getting back @Joshua1985! Too bad this doesn't work! ![]()
Since your Surge is still having display issues, I've created a Support Case on your behalf, you should soon receive an email from Customer Support at the email you used to register with the Community forums.
Please let me know if you have questions about it! ![]()
01-05-2018 22:18
01-05-2018 22:18
Hi everyone, i have the same issue! After all, there is a solution to resolve this issue???. Thanks!
Best Answer01-06-2018 02:51 - edited 01-06-2018 05:09
Hey dancosmin,
The solution to my original problem was that I was eligible for a replacement unit (I was still in the 2 year warranty period). So there was no software fix, nor hardware repair, nothing, only full unit replacement. I was still extremely happy and satisfied with this solution at that time.
Fast forward to december of 2017: the replacement unit started to show the exact same defects after 8 month usage but this time I was not eligible for a replacement (I run out of the 2 year warranty since is counted from the original units activation). I was offered a one time discount from the price of one of the lower tier fitness trackers, which I passed and went for a full price Ionic. So basically I gave Fitbit another chance, if Ionic* fails on me too, this was the last Fitbit device I gave money for.
My advice to you: contact Fitbit support with your problem, make some photos and/or videos where you can clearly demonstrate the screen defects and if they offer, pass on Surge replacement, and choose the discount on another tracker instead.
*I loved my Surge, I was very satisfied with it besides the screen failure, but Ionic is definitely a big step up. Lighter, the screen is superior, the tracking functions are more refined, the wrist band is more comfortable, battery life is way better and the charging connector is not fiddly anymore (yay!). My hope is that it will last for 2-3 years without any problems.
01-11-2018 07:09 - edited 01-11-2018 07:22
Thanks for visiting the Forums @dancosmin, hope you're enjoying your day @LaszloPrekop! ![]()
@dancosmin Due to the information that you're providing, I'm requesting a new case for you; so you can give more details of the issues you're having with your Surge. Please wait for a follow up email, you should get it shortly.
@LaszloPrekop Thanks a million for your feedback, your comments are important for us, I really hope you can enjoy your new Fitbit Ionic. Please feel free to come back if you have questions.
I'll be around. ![]()
03-03-2018 01:25
03-03-2018 01:25
@YojanaFitbit Have noticed similar issues with my Surge the past few days. Currently at step 1 (restart) of the solution. Will monitor it for a while.
03-07-2018 04:56
03-07-2018 04:56
Nice to see that you're digging into the Forums @ask118, let me give you a warm welcome to our Community. ![]()
Thanks for posting you comment, please keep an eye on your Surge and let me know if you have questions about it. Hopefully it will be working just fine after the restart.
07-30-2018 09:51
07-30-2018 09:51
Hello!! I was wondering how I can get help as well. My fitbit is doing the exact same thing.
08-03-2018 13:53
08-03-2018 13:53
Hi @daisypinkrose, it's great to see that you've visited the Fitbit Community, welcome! ![]()
Thanks for posting your inquiry here, for you to have the best possible experience; I've requested to our support team to create a case on your behalf. You should soon receive an email from customer support at the email you used to register with the Community Forums.
Let me know if you have questions about it.
08-12-2018 21:28
08-12-2018 21:28
Yojana, will you open a new case on behalf of my Fitbit surge. It has the same issue. I already started a case on 7/17/18. This is my second surge replacement already. They said my original purchase is out of the warranty period.
However, I never took pictures or anything to ellaborate the true problem. Do you think they might make an exception or not? This Fitbit isn’t even 4- months old. What to do!?
Thanks!
08-17-2018 14:13
08-17-2018 14:13
Thanks for getting back @SunsetRunner! Thank you very much for confirming those details. I requested a case with our team, so you will be contacted shortly. I hope they can help you out with your Surge. Let me know if you need anything else.
I'll be around.
Best Answer10-31-2018 06:25
10-31-2018 06:25
Hello!
I am also experiencing this issue with my Fitbit. I’ve attempted to reset multiple times, yet it still shows signs of artifacts as I scroll. This is a replacement Fitbit from a previous one with a broken band.
