When starting an exercise (Walk, run...) with GPS, my Surge records (from time to time) wrong waypoints, sometime several 100m away from the correct position (ater message 'GPS found'). I suppose the device in that case not 'connect' to a sufficient number of GSP satellites.
Consequently, the path followed and fe. running speed are recorded wrongly.
Questions.
Thanks
I've noticed you are new around @wdelaet, so let me give you a warm welcome to our Community. Regard your last question at the moment you can only sync your GPS course without the possibility to modify your route. There are some p[ossible causes that can affect your GPS activity: The environment you are in can affect the signal strength of GPS, if you are running in an urban environment with many tall buildings, it may take your Surge tracker several seconds to get a fix. For best results, wait for the GPS fix before you start your workout.
If this is not the case please try a restart, if you need the steps I have shared a post with the procedure.
Keep me updated how it goes, I'll be around.
