Lately my 2-year old Surge has been failing to synch my run data with my dashboard. The steps data is being transmitted - just not the run data. I've tried rebooting the watch several times to no avail. Anybody have a solution?
08-18-2017
10:19
07:02
08-18-2017
10:19
07:02
Hey there @Shaw54 and @Clarebear29, it's great to have you here in the Forums! ![]()
@Shaw54 Exactly! Your update is correct, as you can see in this picture the option Treadmill doesn't have the option to connect with the satellite; since this activity doesn't need to be tracked using GPS. So, you're right! Keep using Treadmill run for indoor activities and Free Run for your outdoor runs. That should work for you!
@Clarebear29 In your case some times high buildings, trees and weather may cause an interference on your GPS signal, but it sounds odd that only one tracker is having this hard time. You can restart the Surge tracker to fix any hardware issue the tracker may be having. For best results, wait for your Fitbit to find the signal before you start your workout. ![]()
Keep me posted on the outcome, I'be glad to keep helping you out! ![]()
07-01-2017
07:51
07:02
07-01-2017
07:51
07:02
Hello, @Shaw54! Welcome, welcome!
Hmmmm...this sounds very weird. Just a question how are you recording this running data? Are you using the running option on your Surge's exercise menu,or are you using SmartTrack?
Please provide as much details as you can of the situation so I can better assist you.
It is weird. The running data transfers whenever I'm outdoors using the GPS. However, when I run on an indoor track, using the "Free Run" option, the watch tracks the run stats (I can check the time/distance/avg heart rate) but the data does not transfer to the Dashboard. Maybe I should be using the "Treadmill" option for indoor running?
An update. I tried the "Treadmill" setting and the data transferred successfully. So it appears the "Free Run" setting does not work indoors.
Just got back from a long run and mine is doing the same. Steps and floors have been logged but the run map hasn't appeared.
08-18-2017
10:19
07:02
08-18-2017
10:19
07:02
