03-29-2017
07:20
10:12
YojanaFitbit
03-29-2017
07:20
10:12
YojanaFitbit
Hi,
I have been using my fitbit surge for about two weeks and everithing worked fine until yesterday.
When I plugged to recharge, it sudenly gave me a jump on my steps of 10k and after that it stop recording and tracking everithing. The battery also change from lasting 3 days, to barely few hours.
It connects and runs everything, but it's not tracking.
Moderator edit: Clarified subject.
How you doing my friend @Menp80? Welcome! ![]()
Wow, that's odd. I'd recommend restarting your Surge a couple of times and then try reconnect it with your Fitbit Account again in case that it is related to the firmware update. If you're using a mobile device you can also disconnect it and reconnected with these instructions. You Fitbit Surge should improve too after doing so.
Hope this helps your little buddy, I'll be around! ![]()
Best AnswerThanks Yojana,
Actually, I've done all that several times and the result remains the same.
In fact it got worst. After charging it, the screen went dusty with pixels and the next day it showed the battery sign with an "!" (I beleive is for a damaged battery). However, the next day it started up normally but the lack of tracking remains.
Hi @Menp80! Thanks for getting back and letting me know what you have tried to fix the issue! ![]()
Sorry that it got worst! I would recommend, letting your Surge battery drains completely out, then clean the charging contacts on the back of your tracker. These contacts can become obstructed by microscopic dirt or debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this may damage the plating and result in corrosion. I'd like to try that to see if helping the battery to make it work properly, we can fix the hardware too. ![]()
Then charge it in your Computer for about 3 hours and follow the tips to improve your Surge battery life. Then restart your Surge again. Please keep me posted on the outcome!
