08-17-2018 12:53
08-17-2018 12:53
It seems that a firmware upgrade has made my surge useless as it will no longer swipe to view other screens. The reboot did not help!
08-24-2018 10:18
08-24-2018 10:18
Hi guys! I really appreciate the time you took in posting in this thread @roketmn! Welcome to our new member @28IF!
@28IF If you already tried the restart on your Surge with no luck, you can try this suggestion too, I already got in touch with our team, so they will be checking with you too.
@roketmn Thanks again for your patience and working through these troubleshoots! Keep an eye on your inbox for next steps.
Keep me posted! ![]()
Best Answer08-19-2018 07:10
08-19-2018 07:10
Hi @roketmn! Thanks for reaching out the Forums.
Thanks for trying the restart on your Surge, sorry that your Surge is no longer swiping after the update. Some users have got better results if they do an small changes on the Settings and then try force sync the Surge with a compatible device.
For example changing the time zone in Advanced Settings in the Fitbit app (under the Time Zone option, turn off "Set Automatically", select a random time zone different from home time zone, and re-sync). You can change it back later on. It usually does the trick.
Give it a try and keep me posted please! ![]()
Best Answer08-20-2018 17:12
08-20-2018 17:12
Thanks for the tip; however it was a waste of time as the surge still does not respond to swiping!
08-21-2018 16:29
08-21-2018 16:29
Any luck getting the swipe problem fixed? I'm having the same issue. The Fitbit swipe stopped working. My workout options are now FREE RUN or FREE RUN. Reliability is not exactly a strength of the Fitbit is it? I've had sync challenges with this device since the day I got it and now it's pretty much of no use to me.
08-22-2018 08:04
08-22-2018 08:04
08-24-2018 10:18
08-24-2018 10:18
