08-19-2017 20:37
08-19-2017 20:37
The screen on my Surge will show the time, the buttons work, so I can get to exercise mode, but the touch screen will not work at all. If I swipe to the left to see my steps, the watch won’t do anything, as if I never have touched it. I can not restart it, as the screen won’t work, but I can sync it to my iPhone. How do I fix this? Thanks in advance.
08-14-2018 05:06
08-14-2018 05:06
Patients worked for me, I had to set it and reset it several times, take the app off put the app back on my phone, go back redo reset it everything else, and I finally got it to work right it kept telling me it couldn't find my tracker but I finally got it, patience is what it is
Best Answer08-19-2018 09:52
08-19-2018 09:52
Nice to see that you're digging into the Forums @cdmueller103, let me give you a warm welcome to our Community @Myron711.
That great @Lilly18! Thanks for sharing your experience.
@Myron711 You can tried something similar, we usually don't recommend uninstalling the App but your can give it a try and then try these syncing steps to reconnect your Fitbit. Some users also have reported better results if they do an small changes on the Settings and then try force sync the Surge with a compatible device.
For example changing the time zone in Advanced Settings in the Fitbit app (under the Time Zone option, turn off "Set Automatically", select a random time zone different from home time zone, and re-sync). You can change it back later on. Good luck!
Keep me posted.
Best Answer05-14-2019 19:58
05-14-2019 19:58
My surge won’t swipe, stuck on run. I can’t get to the other functions. It’s almost 3 yrs old. This really stinks for a $250 product. I already restarted etc, it didn’t work
05-25-2019 19:30
05-25-2019 19:30
I don’t know how reliable other smart watches are as compared to a Surge. I only know I’ve gotten used to mine and I like it. I’ve had some issues with it such as the breaking bands. My first Surge had that issue, and FitBit sent me a new one gratis which was nice, but they didn’t ask me for my original watch, so I kept it. Later, I found out there were many vendors on Amazon selling replacement bands, so of course I got one. Not expensive! Also, you can get band covers, which prolong the band life, and they work. My replacement Surge just stopped working, (not getting past the icon), and I thought that one was done, until I got a referral to JoesGE. Apparently they can fix just about anything on a Surge. They replaced my main board for $50 total, including shipping both ways. Getting ready to send them my original Surge which got the spiderwebs on the screen so won’t swipe. I expect the bill to be about the same. To me, even though there have been problems, there are cost effective solutions versus buying a new smart watch I have to get used to. And since I have two, I’ll always have one to wear.
Best Answer08-05-2019 05:45
08-05-2019 05:45
I had the same problem with my Surge and this is what worked for me.
I found that the Heart Rate monitoring was causing it to freeze so I did the following:
1 - turn off Heart Rate monitoring from the app and allow the Surge to sync.
2 - remove the Surge from my account.
3 - connect the Surge to my account.
It's been 48 hours now and the screen is is still responsive. I can scroll through all of the screens.
08-05-2019
05:50
15:09
LizzyFitbit
08-05-2019
05:50
15:09
LizzyFitbit
I went out and bought a Garmin, no more issues with cheap stuff
Moderator edit: removed personal information
Best Answer10-02-2019 19:56
10-02-2019 19:56
Have had all 3 problems mentioned, touchscreen won't swipe; moisture under the face; strap broke just after the 1 year warranty was up and Fitbit said they can't fix it as the strap cannot be replaced, but would give me 25% off if I bought a new Surge. Like that's gonna happen. I now have a $250 paper weight. I would not buy another of these for 1/4 of the price. Fitbit doesn't care about their customer service and there are many options out there now.
10-03-2019 20:14
10-03-2019 20:14
New bands are available on Amazon. I like the KingAcc. So are band/case covers which make the bands last longer. The Surge is susceptible to screen delamination which is manifested by a spiderweb type cracking appearance. This makes the screen virtually unswipeable and it must be replaced. This can be arranged for $55 complete, including all shipping by an outfit found at JoesGE.com.
10-22-2019 16:28
10-22-2019 16:28
Amazon. I like the KingAcc; it’s very close to the original in flexibility. Others I’ve tried were too stiff.
Best Answer12-11-2019 15:22
12-11-2019 15:22
Leave it under your pillow.
Always Works.
Best Answer12-28-2019 13:11
12-28-2019 13:11
This worked and I am so happy!! I usually wear my Fitbit everyday so getting rid of it will be hard.🤗🤗
Best Answer12-28-2019 13:48
12-28-2019 13:48
Well unfortunately I lost the charging cord for about 8 months and bought a new cord and charger and charged it up and the problems started again... this time I got a grey screen and then it went to lines running top to bottom and then went to blank screen and the backlight on.... I give up !!
Best Answer12-28-2019 13:51
12-28-2019 13:51
Best Answer12-28-2019 13:57
12-28-2019 13:57
Best Answer12-28-2019 13:59
12-28-2019 13:59
03-25-2020 02:30
03-25-2020 02:30
Thanks,your info worked
03-26-2020 09:17
03-26-2020 09:17
Awesome! Glad to be of help!
