07-15-2018 17:23 - edited 07-15-2018 17:33
I have restarted my surge several times. I have forgotten the device several times. It still won't swipe to show anything but clock and/or run. What do I do to fix it?
07-29-2019 12:46
07-29-2019 12:46
Hello, late in the day for a reply but i had the same problem, tried everything suggested on the forum, nothing works. I believe the moderators know this as do the manafacturas, the support people were hopeless, my surge is only eighteen months old but their suggestion is to buy a new watch. No surprise there. Wont have another of these things, useless watch, support on a parr.
07-29-2019 20:11
07-29-2019 20:11
Hi,
Thanks for the heads up I will just have to look at my steps on my tablet then by the looks of things then.
07-29-2019 22:43
07-29-2019 22:43
I have the same problem. A while back now, my Surge quit responding to swipes on the screen. All I can use it for now is a basic watch. No other features are accessible.
07-30-2019 01:04
07-30-2019 01:04
07-30-2019 08:34
07-30-2019 08:34
Hi, I just received another reply from the community, They will offer a discount on a new Fitbit but it's not a very generous offer. Well I will not be buying a Fitbit again if this is an on going problem, I will find another brand that I hope will not fail in the task it was intended to do.
09-16-2021 05:23
09-16-2021 05:23
I have the same problem and tried letting the Surge battery go flat.
I've deleted it from my account on the app; tried resetting and the other steps listed above; all to no avail.
Given Fitbit lost a heap of my data about 3 x years ago, meaning my records on my account are incorrect and the shoddy support available, plus the bubbling effect on the strap(s) - yes, my replacement Surge bubbled up when <12 months old - I think it's time for Fitbit and I to have a parting of the ways.
09-20-2021 10:08
09-20-2021 10:08
@Divergirlgail 99% isopropyl on the contacts is excellent maintenance, well done! Unfortunately, this has nothing to do with swiping. First, reset your Surge (hold left and bottom right button around 15 seconds), if that doesn't resolve, it's one of two problems: 1) the second cable that connects to the display is disconnected, or 2) it's broken and unrepairable without replacement. If the reset doesn't resolve, it's the highest probability is your display is permanently damaged. Sorry.
09-20-2021 10:10
09-20-2021 10:10
@Kaijai32 regarding "not able to restart my surge because my swipe function does not work", just hold in the left button and the bottom right button for 15 seconds to reset a Surge.
09-20-2021 10:18
09-20-2021 10:18
@Ragebe why do you suspect allowing your battery to die or removing/adding would resolve screen swiping issues? I've serviced hundreds of Surges and have often resolved this issue. Letting a Surge die or removing it and adding it will not fix your screen swiping. It's fixable with a reset, or it's a disconnected cable or a defective digitizer.
PS. Consider buying a replacement band?
09-20-2021 13:08
09-20-2021 13:08
@Williger why do you not read what is written?
I clearly stated I had tried the suggestions already given above, in order to effect a repair.
I have 2 x Surges and 2 x new bands.
I suspect I have in my 30+ year career as an electronics engineer, repaired a great many more - and more complex - devices than your few hundred devices.
I suggest you re-read my post, somewhat more carefully, before launching into your diatribe.
09-20-2021 16:08
09-20-2021 16:08
@Ragebe DROP the condescending attitude and bullying, it doesn't motivate people to jump in and try and help you. Your supposed 30+ years of experience working on anything doesn't directly apply to the Surge, or you would've resolved this on your own. You've not answered the questions. Unsure why you suspect allowing a battery to die would somehow fix a broken digitizer. Perhaps you can explain this, considering your expertise?
BOTTOM LINE: If not resolved with a reset, the problem is the digitizer.
