Got the surge for Christmas. I don't check progress everyday. Checked my phone 2 days ago and my tracker can't be found. Tried uninstalling and reinstalling app. Nothing is working. I have a Samsung Galaxy s7 edge
Hi @Weathergirlwiz! I think that I already responded you in a different thread. When you try to force sync your tracker with no good result. It's best to disconnect it completely from the Bluetooth and from the Fitbit App. So you can reconnect it later on. Did you try those steps? I'd like to know more details of the steps that you already tried and also the model of device that you're using.
Please keep me posted! ![]()
Thanks for your suggestions. But they didn't quite work. I followed all the steps in your last series and was in a repeating "try again" loop It stays "searching." At one point it did say "We Found!" and "connecting " but then that failed. What next to try?
I've noticed you are new around @rscullin, so let me give you a warm welcome to our Community. ![]()
Thanks for trying those steps! When your Surge is having hard time connecting but it's giving the option to try it again. I'd recommend trying again restarting the tracker several times and if you get the error again force quite the Fitbit App and force close the Bluetooth on the phone. Remember to check that both your phone and Fitbit App are up to date. Which model of phone are you using? Is there any option to use a computer to make it connect via Fitbit Connect?
Keep me posted! ![]()
A number of us started having sync problems with Samsung Galaxy 5's when it recently did a software update. Here's the thread:
I don't know if something similar is happening with the Galaxy 7's.
Hello @JayMR thanks for this information. @YMishtal welcome to the Forums! ![]()
@JayMR Thank you for bringing this issue to our attention, if you're using a Samsung device and you started having syncing issues after receiving a system update on or after August 8, 2017. I wanted to let you know that our team is still working to understand the changes that were included in the system update provided by Samsung. These types of bugs are very unpredictable, sometimes the solution is very simple and other times the solution takes more time to develop. ![]()
You can keep up with the information provided in this thread: Fitbit trackers not syncing after Android software update 8/8.
@YMishtal So glad to know that your Surge started working after the restart. Let me know if you ne
Thanks a million for your patience! ![]()
You're welcome @JayMR! Thanks for the heads up! Feel free to keep feeding that thread with your information. User usually alert us and help us with most recent information. I'll be around in case you need anything else!
Happy to see you around! ![]()
I've noticed that the Surge is very inconsistent with the bluetooth connection. I've had similar issues, and follow all the troubleshooting, but it keeps losing itself on occasion. I've found that I have to switch the Surge Bluetooth on occasion from Classic to Not Classic. I don't really know what they mean, but when it stops working on one, it seems to work on the other. Why it changes I don't know, and don't care, but it's very irritating that it does this. Possibly it's related to one computer having the Surge receiver attached, where the others only connect with native bluetooth?
Hi @SunsetRunner, thanks for your feedback! It's nice to see you again! ![]()
I'd like to know if you're currently syncing your replacement with a mobile device or with a computer? And when you mentioned connecting with Bluetooth Classic, is it because you're using the Music Control option or are you still referring to the syncing process? Too bad that you're having issues with your Fitbit, so I'd like to see if we can fix this! ![]()
See you later! ![]()
Best AnswerHi Yojana,
i have tried all the options to get the buttons on my surge to work, to no avail;
i am unable to restart the tracker as I do not have control of the watch buttons.
i have done option 1-6 including deleting the surge from the Bluetooth , removing the surge from the Fitbit app & resetting up the device on Fitbit, Bluetooth is back on.
Before all of the above, I turned Bluetooth off & back on, I changed the watch face screen.
what can I try next.
Thanks Gary
It's great to see that you've visited the Fitbit Community! ![]()
Thank you for the steps you've tried to help your little buddy, you did a great job. Sorry that your Fitbit is not responding, for you to have the best possible experience, I've created a support case on your behalf.
Keep an eye on your inbox!
06:55
08:52
YojanaFitbit
08-21-2018
06:55
08:52
YojanaFitbit
Hi, i have tried the method as mentioned but my fibit is having a problem when restart. My fitbit surge only able to shown fibit logo for about 15 mins and won't sync even with my Bluetooth on.
A warm welcome to the Fitbit Community @Quinces. ![]()
Thanks for trying those steps with your Surge. Can you please connect your Surge on your computer and while it is charging try to restart it again. You can try to do so a couple of times, since your Surge seem to be stuck on that process. Then please try please confirm that your Fitbit App and phone are up to date first, then you can follow these steps:
This should solve any syncing issue that you're having, please keep me posted on the resolution! ![]()
