First thing to try when a fitbit misbehaves is a restart using this procedure:
https://help.fitbit.com/articles/en_US/Help_article/1186/
Give it a few tries as it doesn't always work.
02-24-2017
05:49
12:10
YojanaFitbit
02-24-2017
05:49
12:10
YojanaFitbit
My surge will not sync or update. I have already reset it but it still will not work.please help.
Moderator edit: Clarified subject.
Hi there @Jessiebailey. It's great to see you in the Community! Thanks a million for the suggestion @SteveH!
Congrats for your new Surge! I'd like to know which device you're using to sync. You can check the requirements to sync with Fitbit products to double check compatibility first. If you're using a compatible device, for example a cellphone you can try some steps to reconnect your Surge with your Fitbit App. ![]()
Give it a shot and let me know if that works! ![]()
