01-17-2017
01:36
04:52
YojanaFitbit
01-17-2017
01:36
04:52
YojanaFitbit
Hi, I am having a problem changing the time on my surge. I have tried all the usual solutions suggested on this forum - nothing is working. The app advanced settings won't change from my home time zone to the time zone of the country I am now in - it switches over but as soon as I return to the dashboard to sync it defaults back to my home time zone. Help!
Moderator edit: Format.
01-17-2017 05:02 - edited 01-17-2017 05:03
Thanks for stopping by guys @ELF48, welcome! Hum! That's strange. Have you tried the suggestions in this post. I would like to know which country and Time Zone you're in and which is your home Time Zone too. We need to fix this!
I'll be around!
01-17-2017 07:18
01-17-2017 07:18
01-17-2017 18:28
01-17-2017 18:28
Hi!
I'm having the same problem with not being able to change the time zone in my Fitbit app. The time zone in advanced settings is set to London where I was recently ( I am currently in Canada where I am based). Consequently, my Surge time is 7 hours out. Every time I try to change the time zone in advanced settings either manually or by turning Set Automatically off and on again, it switches back to London either immediately or when I return to the dashboard. I've tried everything - all the suggested time zone work arounds, rebooting my phone, logging out of the app and closing it, removing my Surge and reinstalling it and even erasing the app and reinstalling it. I've had problems before syncing the time zone but that was solved by the usual tricks. This seems to be a software problem manifesting in the advancing settings area. Can you help?? It's a pain having a watch which doesn't read the correct time! Thanks.
01-18-2017 00:56
01-18-2017 00:56
I suggest you got to your personal settings. Delete reference to your home city, just leave it blank, change the time zone and you should be OK. I have spent over a week trying to come to terms with a watch that told the wrong time having travelled from Switzerland to Ireland. No help from Fitbit so I went to the blog and there I found the solution from someone far brighter than me. It is a shame that Fitbit can't get their act together.
01-18-2017 05:51
01-18-2017 05:51
01-18-2017 08:41
01-18-2017 08:41
01-18-2017 08:45
01-18-2017 08:45
Thanks for taking a break from stepping @ELF48, @Sc47 and @Pelekas! If you're having issues changing your Time Zone, as @Pelekas mentioned you can go to your Fitbit.com Dashboard on your computer or on your phone browser, click on Settings > Personal Info > Country (select country) > City (leave it in black) > Submit.
Apparently, this is a bug in the Account, Fitbit is aware of the issue and is working on a solution.
Let me know how this works for you!
01-18-2017
10:19
07:06
YojanaFitbit
01-18-2017
10:19
07:06
YojanaFitbit
Thank you, Yojana. This is clearly an issue for many users who are travellers, thus, I'd hope you get to fix the bug without delay as it does not reflect well on your products.
Simon C
Moderator edit: Removed personal information.
01-18-2017 11:22
01-18-2017 11:22
This is working fine since a few minutes ago, you can now change the time zone. I was facing the same problem till about 10 minutes back.
01-19-2017 07:17 - edited 04-12-2017 07:52
Thanks for popping by the forums @Pelekas and @iyersn! I really appreciate you sharing this info. I'll be checking this information with other users to see if the issue was resolved.
@Pelekas Please try to do it again to see if you have the option to change it now.
I hope to see you around soon!
01-19-2017 09:21
01-19-2017 09:21
01-22-2017 07:26
01-22-2017 07:26
This is the only solution/work around that I found works. I've tried all other suggestions on this board but deleting home city does the trick. Hopefully a bug fix coming soon
01-22-2017 21:21
01-22-2017 21:21
01-23-2017 02:23
01-23-2017 02:23
01-25-2017 07:11
01-25-2017 07:11
Thanks for staying aroud guys @Sc47 and @SunsetRunner! Good news, some users as @iyersn are reporting that you can change your Time Zone info with no hassle!
Please try to do so and let me know!
I'll be waiting for your comments!
