12-05-2017 13:41
12-05-2017 13:41
It was only wet in the rain now it don’t work at all
12-05-2017 20:13
12-05-2017 20:13
Put it in a bowl of rice for a few days. Hopefully it will come back
Wendy | CA | Moto G6 Android
12-05-2017 20:38
12-05-2017 20:38
12-06-2017 14:23
12-06-2017 14:23
@Average-Bull If moisture got in once then it will always get in. If the warranty is still good then contact Customer Service. One final note. The Surge has been discontinued and replaced by the Ionic.
12-06-2017 15:58
12-06-2017 15:58
12-12-2017 10:47
12-12-2017 10:47
I've noticed you are new around @Average-Bull, so let me give you a warm welcome to our Community. Thanks for the suggestion @VF31AE3 and @WendyB. ![]()
Thanks for the feedback, it's very important to us to have your thoughts in regards our product and your customer support interactions. For you to have the best possible experience, I've created a Support Case on your behalf. Keep an eye on your inbox!.
I'll be around in case that you have questions about it. ![]()
12-13-2017 10:20
12-13-2017 10:20
Any chance of getting a replacement free of charge .
12-14-2017 07:28
12-14-2017 07:28
Hi @Average-Bull! Our team will give the information that you need after checking your warranty options.
Have a good one! ![]()
12-14-2017 11:16 - edited 12-14-2017 11:23
Originally Surge shipped with these specs:
http://www.smartwatch.me/t/fitbit-surge-fitness-watch-specs-features-reviews-pricing/581
You won't find any Fitbit literature that states that any longer (that I can easily find). I went through 3 Surges (Fibit kindly replaced 2). I did not shower, swim, etc with the Surge. They would fog internally from just working out. Eventually bpm sensor would fail, or would stop charging, turning on. Drying it out worked for awhile.
I'm regretting getting the Ionic. Though it's living up to the waterproof claim, there are new frustrating issues. Even with latest updates, syncing is like pulling teeth.
12-15-2017 13:49
12-15-2017 13:49
Thanks for sharing this information @LwrHrtRt! Your feedback is important for us. Would you mind explained what type of issues you're having with your Fitbit Ionic? I'd like to assist you with that. Since as you mentioned you no longer have a Fitbit Surge.
I'll be around!
